Question about Canon PIXMA MP470 All-in-One Printer
Printer MP 470 does not properly grab paper and causes paper to jam
Cleaning of the roller !!!!!
Thanks for offering assistance
Posted on Oct 08, 2009
Paper is not loading properly causing it to jam.
As the printer starts to grab the paper gently hold the top piece. Usually if there's nothing wrong mechanical the rollers that grab it are dirty. May have to it a couple of times. Card stock dose this the best.
Mar 28, 2016 | Office Equipment & Supplies
Jam in duplex area
Its is trick..If its more then two pages print, printer grabs second page even first page in duplex unit., here its confusion. Check with simplex single print, see any paper mismatch error? or printer throwing paper in output bin after successful print?. No.. check fuser out sensor or paper out roller.
Print only two pages matter in duplex, check where paper struck? if paper our roller not grabbing paper back properly in time (slipping while grabbing back) gets jam error.
Always ensure that select proper paper size in printer.Other than this it may major issue, need technical knowledge..& possibilities are less to judge the exact problem..
Keep update us to resolve the issue.
Aug 22, 2014 | HP Color LaserJet Professional CP5225dn...
I have a Canon MP 210 with an E3 error message (paper jam) though there is NO paper jam. The paper feeder is spinning but doesn't grab the paper. Please help! Thank you, Robin
I think there is a paper jam or something stuck in the sensor that is making it think there is a paper jam. It may be a very small piece of paper which you have missed. Look again.
Jan 04, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
My printer keeps giving a paper jam error no paper is jammmed
hi....
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
if this doesn't fix your problem then u can go the following links....
1) http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
2) http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/colormfc/mfc240c_all.html?reg=us&c=us&lang=en&prod=mfc240c_all
if these solutions helps you then rate for my solution...
thank you....
Jul 19, 2009 | Enlight Intel Xeon 470 WATT EN-470 MP...
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
Paper jam in printer
Check paper moisture content. What kinda weather are you experiencing? - very damp?
Dec 30, 2008 | Enlight Intel Xeon 470 WATT EN-470 MP...
Printer says paper jam, but no paper in there
use a flash light check all paper path, specially the area around the toner. all you need is a small piece or other (dust). There is a micro switch that detect the paper travel. so if anything preventing the switch to open, you will get error message.
after that, open the toner door, reseat the toner and close the door. the pirnter should return to normal.
Oct 23, 2008 | Enlight Intel Xeon 470 WATT EN-470 MP...
C1100 mp error
The MP E error relates to the registration assy on the rear of the machine. There are 22 possible causes of this error. I suggest you get a service manual for the machine and work throught the easier checks one by one. You can get a manual from http://www.TheServiceManualShop.com or http://mikeburton.tradebit.com/
Jun 11, 2007 | Epson Aculaser C1100 Printer
Canon PIXMA MP470 All-in-One Printer Logo
253 people viewed this question
old marine
old marine
