Question about Elements Of Design EVTC3291 NAPLES Siphonic jet one-piece toilet S-trap 12"
Sometimes when showering I hear bubbling in toilet.
    Sniper:
  • 61 Answers
Either your plumbing is not vented properly, or your vent is plugged. If things drain and flush ok, you may not need to repair it. However, if you don't get a good flush in your toilet, the venting may be the problem.
Posted on Oct 09, 2009
How do I fix a toilet that bubbles (small air bubbles from below) and flushes slow, and not completely very often?
Remove the toilet & have a plumbing company power snake
as much of the entire homes waste drain as possible
Maybe clogged inside the home on most runs & also out to
the street,have them do as much as they can, out to the street
Remove all toilets, so they can do good job & you can check &
clean them from under it
Have them run a camera down ALL drains & to the street
Jul 19, 2014 | Briggs Abingdon Ada Toilet Express
Vanquish shower goes hot and cold sometimes
Are the pressure ballance taps? If the shower is on and someone flushes the toilet the water will get hot in the shower,if they are not pressure ballance taps,or if they are the cartridge needs to be replaced in the tap.
Apr 18, 2013 | Home
Sewage backs into the shower when the toilet is flushed
Obviously the drain line from your toilet to main drain out of the house ( used by upstairs ) has a blockage from your toilet line to "Y" in to main drain line. Depending on how it has been plumbed, there may be a clean-out between the 2 that can be used to remove the blockage. Your drain for shower is piped in to same line as toilet, thus when blocked at other end, overflows to shower. You can try some drain cleaner down shower drain if it will go. You might get lucky and release the blockage before plumber shows up .
Sep 16, 2012 | Home
Toilet bubbles when tub drains could be from stuck toy in tub overflow?
The bubbling sounds like it's trying to get the air it needs to drain. Kind of like holding your finger over thr the top of a drinking straw and then lifting it out of the water. The water won't drain out until you lift your finger off the straw, allowing air to come in so the water can drain out. If the vent is clogged it could cause this. Squirrels dropped walnuts down mine and clogged it. The vent is the pipe that goes up through the roof, nearest to the toilet and shower. If the shower drain vent line is clogged it is possible that it could be sucking the air it needs through the toilet, sometimes actualling pulling the water out of the toilet. This is not very common but it can happen. If you can get on the roof and get a garden hose into the vent line(s), you can tell if it is clogged because water won't drain, it will come back out. You should be able to turn the water on full blast and it will drain normally if the vent is clear. It's possible that there is a connection between the toys and your problem, and the way you access that drain line is usually thru the wall on the opposite side of the shower controls/drain. I would start by running water down the vent lines on the roof. Good luck.
May 02, 2012 | Home
When I flush my macerating toilet the shower floods with the toilet waste. How can this be fixed.
you have a blockage in drain system. also make sure the air vent is ok.
Jan 18, 2012 | Saniflo Home
I have a saniflo and the shower doesnt drain straight away and when u flush the toilet it bubbles up the shower !
This sounds like a HOUSE plumbing issue. Is the line porperly vented? Bubbling sounds like the line needs venting. If you cannot go through the roof, they now make local vents that work.
Jul 11, 2011 | Home
Occasionally my Saniplus pump runs but doesn't drain. It seems to happen when there is a moderate amount of bubbles created. i.e. when I have showered with a shower gel and the gel foams up to create...
This sounds as if you have a venting problem if there is no air introduced into system then it cannot drain,even with a pressure pump system,the only other thing is that the pump and grinder system is faulty,if still under warranty contact mftr.
Jun 19, 2011 | Saniflo 002/005/007 Saniplus Toilet with...
A saniflo ensuite shower room that is
If you mean that it self activates then the non-return valve is at fault by the sound of what you say
Nov 24, 2009 | Saniflo & Saniplus& Macerator Pump
Elements Of Design EVTC3291 NAPLES Siphonic jet one-piece toilet S-trap 12" Logo
194 people viewed this question
Top Elements Of Design Home Experts
john h
Tom Chichester
Are you an Elements Of Design Home Expert? Answer questions, earn points and help others
