Philips 32PF5331/12 and it starts and shut down in two sec
Hellow, I have a philips 32PF5331/12 and it starts for two seconds and then turns off. how can i fix it?
  • GEORGGIOS STERGIOU
    GEORGGIOS STERGIOU Oct 19, 2009
    it was the oscillator. thanks a lot
  • 5,807 Answers
a) check low voltage regulator 5V
b) check B+ = 95V
c) check horiz oscillator might be blocked
hope i have helped you, thanks for using Fixya!
Posted on Oct 08, 2009
  • 5 more comments
  • Rommel Cana
    Rommel Cana Oct 09, 2009
    if the unit is still in warranty , give a ring on the dealer or visit the manufacturer web site
    and don't open the unit..
    you can also try having the unit unplugged for a while, for at least 10 min, disconnecting
    he RF and audio-video connections, and let it rest for a while.but be sure to note it down,
    first cause you might be bringing it back later.
  • Rommel Cana
    while the unit is unplugged have a check on the service outlet might even need to have it plugged
    on a known good working outlet.
    This apparatus is fitted with an approved moulded 13AMP plug.
    Before connecting the TV to the mains, check that the
    mains supply voltage corresponds to the voltage
    printed on the type plate on the rear panel of the TV. If
    the mains voltage is different, consult your dealer.
  • Rommel Cana
    Errata:
    b) check B+ =24 V
    c) osc might be block (psu)
  • Rommel Cana
    Rommel Cana Oct 16, 2009
    you might need to check on these board
  • Rommel Cana
    please check also of which board installed on your TV
    DPS188APAcat number 9391464
  • Rommel Cana
  • Rommel Cana
    Rommel Cana Oct 19, 2009
    thanks also for using Fixya! congrats!
I have a 83 xs650 starts for 2 seconds then shuts down, what is causing this?
I found that with mine. It would start and run for 10/15 seconds and stop. Leave a couple of minutes and start no problem then stop again. Took whole ignition system to Boyer Bransden and they tested it and the brain box was faulty. Replaced that and bingo. SORTED. Over 40 Years Proven Performance
Jun 12, 2014 | 1979 Yamaha XS 650 SF
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
Ps3 freezes and shuts down after 20 seconds after powering on, what could this be?
I have the same problem. When it is turned on it shuts down within 30 seconds and I need to disconnect the power cable again before it can be turned on (and again shuts down after some 30 sec.)
Apr 11, 2010 | Sony Playstation 3 (PS3) Console
Toshiba A60 shuts down in 3 seconds
Bios may be set wrong(fix by restoring default settings)
memory may be damaged(replace if true)
battery may be low and system shuts itself off(make sure battery is charged)
Drivers may be wrong(replace drivers in safe-mode)
Motherboard or other devices inside laptop may be loose and/or shorting.(Go to local computer fix-it shop or (open up laptop and check for loose connections which may void warranty.))
My guess is your bios needs resetting
Hope I am a help.
Feb 03, 2009 | Toshiba Satellite A60 Notebook
My philips tv won't turn on.
Very unlikely to be the switch. With the power supply shutting down, the problem is probably in one of the circuits that is supplied by it. Unless you know what you are doing, leave it to a technican.
Dec 30, 2008 | Philips Televison & Video
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
Aug 29, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
336 people viewed this question
Top Televison & Video Experts
Electro Med Services...
