Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Canon eos 300d (digital)
When turns on and try anything ... flashes "error 02"
and there is nothing yo can perform
  • Anonymous Dec 31, 2007
    There must be more to this issue than meets the eye, and more than the given 'answer' allows for. I have tried SIX DIFFERENT CF-cards in my 300D, and FIVE of them give an error-2 message ! Fortunately, the sixth -an old, cheap, brandless 512 MB example- works fine and provides enough memory for 140 or so pictures at max res (less in RAW mode of course). I have consulted two dealers who weresimilarly baffled -and tried to sell me a SEVENTH card, which also did not work! And interestingly, ALL of my cards work fine in my Ixus. So I am afraid I have no solution, but would suggest that 'read the manual' is not always going to be sufficient answer...on my experience, I would suggest: try a decent assortiment of different cards before applying for what is likely to be an expensive repair: you might get lucky!
    alan parfitt
Al you have to do is clean the lenses. I 've got the same problem
and it works!
Posted on Jan 17, 2008
  • 148 Answers
Your manual is the first place to look for an error code. then the canon site.
guessing it is a defective on board battery (the smaller of the two) or your main battery is depleted.
try removing and reinstalling the main battery first. then check the on board battery.
you may have a lens partially mounted, or some contamination on either the battery terminals or lens terminals, or a door partially open.
also, you should take out the mem card and check it in a card reader.
none of this will likely be needed if you can find the error code data. it might be that the code is specific enough to indicate the root cause of the problem.
good luck
Posted on Dec 24, 2007
I have bought a canon EOS 300d camera with out cd. bt when i plug my camera to my computer nothing happens .i tried to do download dpp bt all i fine is dpp updater e.t.c . i have windows xp in installed ....
The updater does not need to have a previous version installed, it will install the stand alone program. However DPP is not the program you need to connect to your camera, what you need is EOS Utility. That is also availible on the Canon website.
May 08, 2011 | Canon Digital Rebel / EOS-300D Digital...
Im getting an Error 99 on my EOS-300D Digital Camera when I turn off my YN 465 Speedlite flash gun (still mounted) and then I start shooting manually without the flash. Help please, its a bit annoying, but...
To fix this err99 issue, do the following
1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera.
If it appears again, then proceed to next steps 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera.
If you still get the error you should send your product to canon for servicing.
Apr 15, 2010 | Canon Digital Rebel / EOS-300D Digital...
Tech help
In the manual on page 127:
Err 02
There is a problem with the CF card. Do one of the
following: Remove and reload the CF card, use another
CF card, or format the CF card.
found manual at:
Jun 23, 2008 | Canon Digital Rebel / EOS-300D Digital...
300D doesn't turn on at all.
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
Jan 02, 2008 | Canon Rebel XT / EOS 350D Digital Camera
EOS-300D Flash
your flash is acting to 'fill' for you. fill lighting can be a benefit. if you don't want it, see settings menu to turn off flash until you need it. not difficult and worth knowing how to make simple routine setting adjustments.
good luck
Sep 20, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS-300D not seen by computer/not turning on
Heat and batteries - maybe Try another battery Remove camera software from computer and put the disk in the box. Plug camera in switch it on and set it to upload mode Windows should find it as a new drive or[XP/2000/ME] will put up camera/scanner wizard.
Aug 06, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
124 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
