Question about InFocus SP-LAMP-017 Projector Lamp for LP540, LP640, C16
I have no power when I power on the power buttom. There is no sign of life (Fan, LED Display, noise or nothing). It is as though it is not plugged in or turned on. I ripped it apart to see if there was a fuse blown. There is a fuse inside, but it was good. Can you give me some suggestions? Thanks Sam
    Scholar:
  • 167 Answers
This problem is quite common in the LP640 and the LP540.
I have repaired about 75 of them with this symptom and every one had the same solution.
There are 2 power supplies in the projector. the issue is with the one right the rear panel. If you have moderate electro mechanical skills you can repair it. You will need to remove the power supply to perform this repair. You will also need a good temp regulated soldering iron (and know how to use it well) You will also need an OHM meter. You will find 4 surface mount diodes near one end of the power supply board. these diodes are approximately 3mm X 5mm and black in color. One of these is shorted!! use the ohm meter to measure each one. the shorted one will measure very differently than the other three. one of them will be less than 10ohms. you can buy a replacement diode from DIGI-KEY if you call them you can give them the part # on the bad diode and they can supply you with the same part or an equivalent substitute.
You will need to remove the top board and the screws on the rear of the projector (even the ones on each side of the "D" connectors)
The flexi cables that connect the LCD's to the main board as well as the 3 connectors they fit into are very delicate! Again if you don't know what you are doing you can cause much damage and possibly total the projector. anyway the LCD flexi cable connectors have a very small brown piece that runs the length of the connector opposite from the side the flexi cable is fitted into. This brown plastic pieces are part of the clamping mechanism that holds the cable in. to release the flexi cable the brown plastic piece hinges up toward the flexi cable releasing it. This brown part moves easily so do not force it! anyway if all this is above your skill level have someone else who is qualified do it. You do not need a new power supply! the Diode is about $0.78 and a power supply is closer to $150
Good Luck!
Posted on Dec 11, 2009
Testimonial: "Thanks for the great feedback and followup. I will try this."
  • igams Jan 02, 2011
    This solution worked for me!
    Official service repair wanted to sent the projector to Netherland - obviously there is a central InFocus repair station for Europe. The estimated cost of repair was 400,00 EUR!
    I followed the solution and really find out the shorted diode. It was VS-30BQ100PBF SCHOTTKY DIODE, I ordered it by Farnell and received it in a few days. It was 0,49 EUR for a piece. I also had to bought a better soldering iron, which was 40,00 EUR. The repair was fun and full of adrenaline. I was rewarded at teh end with a tiny green LED that confirmed my success. Thanks, sagertronics!
  • 70 Answers
Sir Sam your projector is deadset, try to open your projector, find thermal switch( if it have cause LCD projector has it) switch it. if problem occur? change power cord, and power supply board.
jahting
Posted on Oct 08, 2009
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
Does not switch on but power on light is on
I would remove the battery, power supply, RAM and hard drive. Plug the power supply in and see what happens when the power button is pressed. If nothing, there is a motherboard issue, possibly a GPU error. If it comes to life, re assemble bit by bit until the culprit is found.
Jan 14, 2014 | Computers & Internet
Front panel 10 pair motherboard plug in configuration
this will do
2 8
. . . . this will be 2,4,6 and 8 pins (from left to right)
. . . . . this will be 1,3,5,7 and 9 pins
1 9
Power Led + in pin 2
Power Led - in pin 4
Power Button # or + in pin 6 (It's no critic the orientation, it have no polarity, is a push buttom)
Power Button GND or - in pin 8
HDD Led + in pin 1
HDD Led - in pin 3
GND from Reset Buttom in pin 5
# from Reset Buttom in pin 7
THE PIN 9 has no connection
Jan 15, 2011 | AOpen AX45-4D Max Motherboard
No singns of life
Sounds as though your ac adapter is bad.But it could also be the power jack where the ac adapter plugs in also.
Aug 07, 2009 | Toshiba Satellite M105-S1021 Notebook
Help! Laptop is dead, no power
1.have you charged the battery long enough?
2.is your charger working?
alternatively it is possible that your charger pin is not receiving power supply. you will need to get it checkd.
Apr 15, 2009 | Acer TravelMate 3260-4874 Notebook
Laptop wont start
What happened to the laptop, was it dropped, did it have any spill or maybe some kind of power surge ?
did you try switching on battry power only ?
Mar 10, 2009 | Dell Inspiron P4 3.2GHz 512MB 40GB...
No Signs of Life
If it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free or you may have to return it to the dealer.
GE Customer Service is here.
Usually they will go by the date on the tag on the oven to determine warranty.
Feb 04, 2009 | GE JES1358 Microwave Oven
Laptop wont turn on philips freevents x51
The most likely problem is that your Hard Drive has Died.
If you can readily access another Laptop HDD, try it and see.
Other than that, I'd say the Motherboard has decieded to give up the Ghost.
Just Remember, A Laptops life expectancy is 3 years, after that you are treading on thin ice keeping Important Documents on it.
Nov 27, 2008 | Computers & Internet
My computer won't start! It was shut down by the start menu and when I went back to it about an hour later, I push the button in to power the computer on and nothing is happening. Yes, it is plugged in...
Unplug it and hold the power button in for up to 60 seconds to discharge.
Is there an I/O button in the back of the computer? Make sure it is set to I.
Apr 10, 2008 | Computers & Internet
Panasonic pt-50dl54j
The 3 times LED code points to no fan rotation. There are 2 fans. Check the larger fan first, p/n = FBL12G12LS, located near the lamp. Even though that fan may be rotating, it may be slow.
thanks
scott
Dec 20, 2007 | Panasonic PT-47WX51 47" Rear Projection...
InFocus SP-LAMP-017 Projector Lamp for LP540, LP640, C16 Logo
790 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
