Question about Toshiba TheaterWide 50HP16 50 in. Plasma HDTV
Toshiba 50HP16 Plasma tv has sound, no picture. Screen is flashing like a camera flash....on-off at random. Volume works with remote. No menu. Screen flickers/flashes. Power light in front is green. TV is only 3 yrs old. Hasn't been moved in 3yrs. Ok untill now. Maybe a board? (i hope) I removed the back, checked fuses with ohm meter,all OK.
  • 2 more comments
  • William J Allsop Jr Oct 07, 2009
    I know it needs repair,,I need to know which board to buy ?? for the no picture problem. sound is ok
    Hello,i need to know what board to replace to repair my toshiba 50hp16 plasma tv. sound works OK. NO PICTURE. Screen just flashes/Flickers like a camera flash.I removed the rear cover.No burnt marks on the boards.Caps look OK. All boards look OK. Fuses are OK. Tv was not damaged.Hasn't moved in 3 yrs. I was watching and the screen just start to flicker/flash.Sound is OK. Volume control works fine.NO PICTURE The screen got warm when it worked.The surface on the rear(inside)of the screen is cold.(aluminum)
    If the power supply is dead, why does the volume work and i can adjust it,(i can hear whatever channel it's on) and the green power light is on the front.NO PICTURE,Just flashes like a camera flash. is there any Test points i can check to figure out what board is not working?
  • Jim Goldsmith
    Jim Goldsmith Apr 10, 2014
    Y-sustain board usually ...two main ics fail
    President:
  • 1,884 Answers
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Posted on Oct 07, 2009
    Problem Solver:
I have a Toshiba TV The picture is good but no sound.
Posted on Oct 25, 2009
TV won't respond to remote or button on the TV
Make sure you are running the Keygen as administrator
Jan 28, 2014 | Toshiba 55UL610U 3D TV
Picture but no sound on a Toshiba Theaterwide HD tv
Hello Iam wondering have you tried to see under the TV setting Audio and see if the fuctions are muted
or try to unplugged the tv and wait for a few minutes plug it back in.
Also when th tv is turn back on or unplugged and plugged back in see if the power button light
flashes red
And listen to the speakers to see if there is a faint crackling
Sep 12, 2008 | Toshiba TheaterWide 50HP16 50 in. Plasma...
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba 50HP16
"Popped"? That sounds like a serious issue that is going to require a warranty repair or a professional TV repair person to address.
May 01, 2008 | Toshiba 50HP81 50 in. Plasma Television
Insignia 42 in plasma tv
cableman try this exactley to the "T" with the instructions in front of you. The procedure resets your monitor to factory settings. On step 13 use the factory setting on the right side menu block not the left. It may or may not work if you have a bad board or eeprom. 1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Jan 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
High def picture is cut off on the sides
I have a Toshiba 50HP15 PLasma flat screen TV. Its been working tone for 2 years now. All of a sudden without warningm the right 1/3 of tghe picture is missing and is black, where as the other 2/3rd of the picture is great picture and in HD. When I press DISPLAY on the remote control is says FULL 720p. When I press the Picture Size button on the remote the message NOT AVAILABLE come on. Anyone with suggestions. Thanks
scotto
Dec 27, 2007 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Open Questions:
Toshiba TheaterWide 50HP16 50 in. Plasma HDTV Logo
1,063 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
