Question about NorStar M7310 Phone
Someone in our office has problems with their handsfree button. They can use if to call out but if they receive a call and want to switch it is not working. I checked the config menu..both are set to Y
  • Clarissa1 Oct 07, 2009
    not sure. I've looked into it a bit more and am thinking they might be turning the microphone off and on (mute) by mistake. I guess if this is the case just hitting the handsfree button again will turn the microphone back on?
  • george  peters
    george peters May 11, 2010
    How are they switching from the handset to handsfree?
    President:
  • NorStar Master
  • 860 Answers
Yup, and to release the call use the Rls key
Posted on Oct 07, 2009
Testimonial: "great to have help right away. Thanks!"
What button do i press to get handsfree
While you are on the call, you should enable "Speaker". Depending on which cell you are using, the option might be on the screen itself or you might have to get into options to toggle the speaker mode.
Aug 12, 2014 | Cell Phones
M7310 Non-Stop Dial Tone
Intercom button/s provide dial tone when they are pressed. They are required to call other phones on your system.
Sounds like your button is stuck or issue with the motherboard.
Dec 17, 2012 | NorStar Meridian M7310 Phone
How do I activate the handsfree mute button on Norstar M7310? When I push outside line, then handsfree, I get dial tone, but cannot dial outside number. When call is incoming, after answering, I cannot...
familirize with devices user manual whether has feature functions requested. Second, ascertain that device was least malfunctioning since acquired. normally, familirising with innovative devices makes expertise in functionality.
Jul 20, 2011 | NorStar Meridian M7310 Phone
When I hit handsfree button it says it is muted cant figure out how to un-mute the phone
If handsfree is enabled on your telephone, any line or intercom button activates the handsfree, if you press the handsfree button after selecting the line then the button activates handsfree mute, Press the handsfree mute button again to un-mute the line.
Jul 04, 2010 | NorStar Meridian M7310 Phone
I want to make and receive handsfree calls using an LG HBM-730 bluetooth device and an LG CF360 phone. I have the bluetooth and the phone connected and can receive calls and make calls. The kicker is...
Hello.
From LG Documentation:
To make a handsfree call from the bluetooth device (Voice dialing)
- Briefly press the PWR/END button to activate “Voice Command”.
You will get the best results if you first record the voice dialing tag through
your Headset.
Hope this helps
Mar 09, 2010 | Cell Phones
Our receptionist's M7324 switches to handsfree mode even though she has used the handset to answer the call and still has the handset off the hook. What can I do do fix this problem?
Sounds like the handsfree button might be stuck down. Try slightly pulling up on the button and see if that changes to the handset.
Jan 14, 2010 | NorStar M7324 Telephone
How to connect my nokia BH-104 bluetooth handsfree to N73 mobile
Most handsfrees need you to hold the on button for about 10 seconds to trigger the pairing. Hold the button until the indicator flashes rapidly.
Oct 03, 2009 | Logitech Bluetooth Wireless Talking Kit...
Can't pair nexus text to speech with my I phone don't have instructions either can anyone help??
Press and hold the 'Call' button on the Nexxus handsfree for 5 seconds. It will then go into Pairing mode. Set your phone handset to search for Bluetooth devices.
Pass-code = 1234
Good luck.
Andrew
Apr 29, 2009 | Cell Phones
Call received automatically when hand's free is in use.
PLS. CLEAR THE CONNECTION BETWEEN YOUR PHONE AND HANDSFREE BY A POINTED PIN. IT MIGHT BE RUSTED.
IF IT STILL EXISTS YOUR HANDSFREE'S ANSWER SWITCH MUST BE STICKED JUST CLEAN IT
IF SITLL YOU HAVE PROBLEM. JUST REPLACE YOUR HANDSFREE WITH A NEW ONE. IT WILL SOLVE THE PROBLEM.
REGARDS
KETAN PATEL
Feb 02, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Problem with Speakerphone
It is maybe some setting called Handsfree. On the phones that work, press Feature *0 and press the buttons on the right from the bottom up. The very bottom button should be handsfree/mute and the next one or two Intercom xx(x). Now check the ones that don't work and see if they read the same. I'm guessing not.
It takes system admin access to turn on handsfree per set. Check with your telephone system manager or installer for the programming.
Carl
Jan 09, 2009 | NorStar M7310 Corded Phone
NorStar M7310 Phone Logo
73 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
