Question about Garden
Changing a drive belt for a craftsman re2000 lawn
Can not replace the belt i pulled off the rear axel and still having problems it is for the drive belt
  • 1 more comment
  • Chuck
    Chuck May 11, 2010
    WHAT IS THE CRAFTSMAN MODEL NUMBER?????? >>>> 9 1 7 . ?????? <<<<<
  • S Harlan
    S Harlan May 11, 2010
    need model and ser number and make
  • Chuck
    Chuck May 11, 2010
    WHAT KIND OF TRACTOR??? WHAT MODEL NUMBER???? WHAT SERIAL NUMBER???????
4 Suggested Answers
lonewolf1996
  • 142 Answers
SOURCE: How do I replace the Drive Belt on a Craftsman
You need to get underneath the mower.Look in the front on the bottom of the engine.You will see the engine pulley.On the side of the pulley you will see a bracket that keeps the belt from falling off the pulley.It is help on by two bolts.Take the bracket off.Now you will be able to take the belt off.
Reinstall the new belt and replace the bracket.
Posted on Sep 02, 2009
  • 61 Answers
SOURCE: Roper 16 hp Lawn Tractor: belt replacement
you need to remove the mower deck there you will see the pullys.
Posted on Sep 06, 2009
bargainbin2
  • 123 Answers
SOURCE: 13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Posted on Aug 29, 2009
How to change the belt on a craftsman rear wheel drive lawnmower
open drive cover take plug out roll belt off pully by pulling it to the side and hand turnig the blade after comes off drive remove blade and take off belt to reinstall do reverse
Aug 28, 2014 | Craftsman Garden
How to replace belt on self propelled front gear drive craftsman 6.25
If it like mine take the cover off on the left rear you will see the belt it also has a cover on the bottom take it off you may be able fo use a screwdriver and froce the belt off if not pull the spring off the outer pulley remove belt and replace it with the new belt replace spring good to go.
Jun 06, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Craftsman 56" lawn tractor auto trans dose not drive forward or revers. tryed purging trans no go checked engagment rod ok, belt seems good. I can push the mower by hand as if the trans were not connected...
somehow did the little freewheel lever get pulled in the rear of the tractor to disengage transmission?..usually out is disengage and in is engaged. look around the back panel behind the rear axle for a small lever you can pull or push in.
Aug 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 675 21" rear self-propelled not pulling
Remove blade and loosen tension system slide belt over transmission and off of the engine
Apr 17, 2013 | Craftsman 675 Torque 190cc 21" RearBag...
My craftsman re2000 starts but wont move...seems like it is stuck int neutral
check the belt tension then check . then check the rod on the rear of the mower to see if the rod you pull when you want to push it is not released
Apr 18, 2012 | Craftsman Garden
How do I get the lever to shift to lift the mower so that I can replace the belt? 19hp, 42", year unknown craftsman turbo
If it is the drive belt do the following place your mower on a level surface set parking brake, remove mower deck, remove belt from stationary idler and clutch idler, pull belt slack towards the rear of tractor , then remove belt upwards from transaxle pulley by deflecting the belt keepers, then pull the belt towards the front of mower and remove downwards from engine pulley Install new belt in reverse procedure
Jan 22, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 42 inch 18.5 hp craftsman riding mower that has started jerking when in a pull .The belt is very loose and has never been changed. could this be the problem.Also can you ck trans fluid on this...
look under unit and check the pulleys may need an adjustment on the engagement pulley which is connected to the foot brake pedal if adjustment good than also check rear pulley unbolt rear cover to access sometimes bolt becomes loose if good and belt is damaged or stretched than replace belt
Aug 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Old craftsman rider rear engine think Model#25621. Mfd.#97036. Serial #733250367Z00077.Re2000 3 in 1, 30'' single deck, B&S 13.5hp unable to locate any info. Please help!!!
I have the same rear engine tractor and cannot find parts anywhere. I did find another model that seems to look exactly the same. The model is 536.270212. It walked me through removing the deck, blade and motion belt. You can find the manual at www.hammerwall.com.. Hope this helps.
Apr 01, 2010 | Craftsman Garden
Need to replace drive belt.Never replaced. 42' Craftsman riding lawn mower. How difficult is this. How do you access rear drive pully
Take a look at how the belt is installed. Then you will have to remove the mower deck and belt from the pulley on the engine. There is probably something by the engine pulley that you will have to remove so the belt will come off. It might be a shoulder bold or a rod with a bolt holding it on. Same with the rear pulley. Then you just have to put the belt on one pulley and watch your fingers so you don't pinch them and turn the other pulley and the belt should go on. reinstall any bolts you removed and install the deck.
Oct 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman 18hp Kohler engine. What is
there is no clutch drive belt needs replacing cost of drive belt $20.00
Sep 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
937 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
