Question about Acer Aspire 4520-5582 Notebook
My power cord connection to my Acer laptop is poor. It seems that the laptop is melting the male portion of the power cord connector..What would you suggest to eliminate this problem?
  • 108 Answers
This problem arises due to internal wire cut at the connector junction, simple solution : cut the powerchord and fix a new connector,
Connector is moulded, the mould can be easily cut and the same connector can be used by soldering the wires appropriately
Posted on Oct 08, 2009
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Will power cord for ld3255vx work for ld4655vx wide screen tv?
Dear Cheryl,
The power cords are pretty standard from all theses TVs.
Please remember that these power cords have 3 pins (male side), being 2 flats and 1 round that connects to the wall. On the other side it also has 3 flat pins cast into the plastic/rubberized female side. These are standard power cables for the majority of the sound/video equipment you will find in the market.
If the connector at the TV (male) is of the same type in power cord you have (female), in other words, if it fits and completely locks in, then, YES! Go ahead and use it. There is no problem whatsoever.
IMPORTANT - BEFORE CONNECTING THE CORD TO THE WALL ("live" power), please test if your connector fits the TV set completely.
I hope I have helped you.
Dec 30, 2013 | Westinghouse " 46"" Class - LED - 1080p -...
I have an acer aspire 7736z laptop and the power doesn't turn on, I tried to remove battery nd plugging power supply then hold power button for 30 seconds and still nothing works
Bottom Line the manual says if the light to not come on when cord is bluged in battery out get a new motherboard. You may also hear a slight ticking like a clock tick.. The Issue is the U58 chip on bottom side of motherboard burns out. sometimes takes out U63, U59 and U64 are same corresponding chip and can fail as well at worst case... Usually just U58..it is a 4812 chip you can get for a few cents...I heard how ever if you replace U58 and think U59 with the U63 chip a 4800IC chip the issue goes away... Trying to confirm... Until I confirm recomend either new mother board or correct U58 chips 4812..mosfet n channel..
Jun 15, 2011 | Computers & Internet
It looks like the plug on the blower melted slightly now the blower doesn't work can it be repaired
Parts are few for these machines (all I found was the blower tube). That being said, you can carefully cut off and remove the faulty male plug and replace it with a repair piece like you would add onto a damaged extension cord (outdoor type). They are made of plastic, but are fairly sturdy. Just carefully cut away the old male connector (the shrod isn't really necessary and remove the wiring from it. After purchasing the male-type plug replacement, rewire it and you will be set to go. To eliminate the male cord and the female end of the extension cord you will use from pulling apart when in operation, just loop the female end cord around the cord of the blower and it will hold in place.
Mar 19, 2011 | Toro 51585 Power Sweep 7 Amp 2speed...
Hi Guy's I have an Acer Aspire 5315 laptop and a 32" Bush flatscreen TV. What cable do I need to connect the 2 to watch movies etc Cheers
Use a 15-pin, male-to-male VGA cable to connect your laptop to your TV. male-to-male means the pins are sticking out on both ends. Since both ends are male, you'll need to find the female VGA input on your laptop and on your TV. This is often called the PC input. Now, connect one end into the TV and one end into the PC. On a Mac, the VGA input is conveniently labeled with a "display" icon. It's recommended that you do this with everything powered off.
Sep 27, 2010 | Acer Aspire 5315 15.4-inch Notebook PC
Recently i have purchased lenovo laptop.they gave me one adapter along with the charger. i dont know how to use it
You would be having one Power cord also with this Adapter.
Just connect the Adapter and Power Cord (Female and male connector) > AFter tht connect the Connector (Hole Side) to the Laptop for charging and the Second end to the Power Plug.
If still have any issues, Please feel free to mail @ guptapankaj8@yahoo.com
Sep 23, 2010 | Lenovo Computers & Internet
How to connect acer travelmate 4720 with LCD TV useing S-Video ports? Will just one connector cord connecting the Acer 4720 with my LCD TV suffice for reciveing and audio-visual through the TV?
Hello, You will also need to connect the audio cable. You can use a male-male audio connector from radio shack along with the s-video cable to solve your problem.
Apr 08, 2010 | Computers & Internet
Battery will not charge nor is able to use AC power to stay on.
Hi everyone it seems to me that the DC connector is loose inside your laptops,try wiggling it about gently at the charger to laptop cord nearer to the dc socket to verify this.Only solution is resolder or new dc socket.
Dec 27, 2008 | Acer Aspire 3680 Laptop
Acer power cord connection
Don't pull your hair out,.. it's not an uncommon issue.
You don't have to replace your board. At least one of them sounds like the connector has come loose
or has issues, and needs replaced. The other sounds like the adapter itself. I ordered a new adapter on
Ebay this morning for about $28 total for a Compaq Presario and all laptop models seem to be about
the same price for adapters on that site. As far as replacing the connector,.. you in luck, there are
several places on ebay that you can send the laptop to ad they will diagnose the laptop and if it
is the connector they have a 1 day turnaround. Think that service is about $100 or so possibly
cheaper. On EBay search for 'laptop power jack repair'.
If you don't feel the value of your laptop is enough to warrant such an expense you can order a
replacement jack instead and try and tackle replacing it yourself. ( there are listings to order
just the power jack )
Feb 26, 2008 | Acer TravelMate 2300 Notebook
Possibly powerplug!
The poor design of the power pin is a major source of problems on almost all laptops. Do a google search for power pin problems and you'll see what I mean.
Problem stems from jerking or tugging on the cable. Every laptop should come with a cable retention device to keep from damaging the fragile power pin.
This video has some pretty good information about it. . .
Dec 27, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 4520-5582 Notebook Logo
221 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
