Question about Accuspray 10 Series Regulator 36-00 Paint Spray Gun
There is only air coming out of the gun without any paint/material. i can feel the material inside the canister bubbling but nothing is happening
    Problem Solver:
  • 5 Answers
Check that valve inside the canister that let the air in and make sure it works freely. Then you'll need to make sure your paint isn't too think. If it is you'll need to thin it.
Posted on Jan 28, 2010
Spray gun problems
did the canister tube fall out? dump the paint out into a saveable container and put straight (enamel reducer) in it and try to clean/clear the unit..adjust the knob on the back of the spray gun it controls the paint flow..
Aug 03, 2014 | Wagner Air Tools & Compressors
Tip
How to clean your air brush to keep it like new
Taking care of your tools and supplies is an essential in their upkeep and increasing the life of your tools. When you neglect to take care of your tools they will get clogged or ruined and eventually will stop working. This same principle applies to your air brush gun, if you don't take care of it and clean in properly after each use it will get clogged and will stop working.
After each use you want to make sure that you get all the paint out, to do this you should add a little bit of warm water to the cup (where the paint goes in) and then pour it out into the trash. You must be sure NOT to use hot water because it could melt or warp small plastic pieces inside the gun.
Fill a bowl or tub with clean warm water, connect the air brush to the tube, plug it in and turn it on. Placing the needle and the cup under the water and pull the trigger. Run water through it for a few minutes to make sure that no color comes out of it. If paint does come out of the gun you will need to change the water.
When the water runs clear through the gun take it out of the water and fill the cup with clean water. While placing your finger over the needle cap pull the trigger. This will make the air flow backwards through the gun causing bubbles to form in the cup. If there is paint stuck in the gun it will come up in the bubbles in this step. Pour the water out and place the needle and cup in water again and pull the trigger.
When you feel that it is clean, take the gun out of the water and spray your gun on a white napkin or paper towel to make sure there is no color in the spray. If no color comes out you are all clean and ready to use your airbrush gun again.
on Feb 06, 2014 | Air Tools & Compressors
Master g22 air paint
Do you have a water separator attached?
Jul 11, 2013 | Crafts & Hobbies
The BBs won't come.the gun won't it's a MCSR01 crosman air gun
With magazine out, what happens after cocking, should get a gush of air, if nothing, spring not latching, or seal leaking badly, have you adjusted trigger, to fine with a spring type, will not latch, so no pressure, can you feel anything happening, nothing at all spring latch, can you feel the pressure of the spring when you cook it.
Mar 15, 2013 | Optics
Spraying kitchen cabinet doors 40 degree weather airless graco sprayer enamel water base paint at first finish is great then bubbles start to form
first problem is the waterbase paints ( ****) the other is how did you mix your paint , you cam trap air in the paint if you padle or stired it without a shaker mixer air will gas out of the paint, tofix this use a foam brush to flaten air bubbles
Jan 23, 2011 | Air Tools & Compressors
I have an HVLP spray gun -I have put water in to test it (I am going to us a cold metal product -Luminore of California) - the problem is that I can feel the air pressure coming out of the gun but not...
adjust needle valve at rear of gun a little at a time , also som gums have a side fan control to adjust the width of the spray. be sure to mix the paint or material thin enough to spray ( read instructions on paint can for mixtures)
Nov 16, 2010 | Air Tools & Compressors
MY CAMPBELL HAUSFELD DH5300 PAINT SPRAYER WILL NOT SPRAY PAINT.
there are several issues that can cause this problem.
I will assume you have used the sprayer before so that will eliminate an incorrect air cap. The only other issues are paint viscosity, worn parts and the number one cause improper cleaning.
Be prepared for a complete disassemble of your gun. Depending on what you spray any residue can become hard as cement and it only takes a small amount to cause problems.
Below is a link to the manual that gives an exploded view of your gun.
Hope this helps but if not please let me know and I will trouble shoot further.
http://www.cpocampbellhausfeld.com/static/manual/www.cpocampbellhausfeld.com-dh5300.pdf
May 22, 2010 | Campbell Hausfeld Air Comp Basic Spray Gun...
Vaper primer gun has intermittent air supply
Does it come with instructions? The material thickness is VERY IMPORTANT when choozing the proper nozzle.
Nov 17, 2008 | Northern Tool Vaper 2.0mm Hvlp Spray Gun...
Accuspray 10 Series Regulator 36-00 Paint Spray Gun Logo
176 people viewed this question
Top Accuspray Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Accuspray Air Tool and Compressor Expert? Answer questions, earn points and help others
