Question about ASUS Computers & Internet
Two months old dead no power
Asus cm5570 2 months old turn on power , and screen comes on shows no signal shuts off no power supply ,fan wont turn on as well.? it was working fine one day next day dead
    Brigadier General:
  • 3,614 Answers
Check the Power cable of your PC for any damaged or burn/cut. Firmly check the connection on the slot of the CPU Power Supply,
Check the Electrical outlet , or better plug the cord on a different electrical outlet.
If all of this has nothing to do and the problem was still there, possible problem on the powersupply are, it is advisable that you have to replace this part, a possible burnt or a short circuit has happen inside, due to some electrical malfunction on your area.
HOpe this helps.
Let me know for any clarification
Posted on Oct 08, 2009
Hp P6000 fans stop after 15 seconds. Hard drive light stays on. nothing on monitor
dead PC, DESKTOP PC ,as old as 2009.
the fans tells you the PSU shut off, for cause.
fans, so you saw all fans turn off or just 1. or 2 of 3.
my pc has 4 fans many have 3;
CPU fan stops ,cpu overheats , PC goes slow or dead. clean the lint off it.
GPU fan , video goes dead. if it overheats.
PSU fan is inside the PSU if it goes bad, PSU is bad.
no monitor stated, is it CRT or LCD is it 15 years old.
if the monitor is 2002 or newer the OSD screen works
even with PC turned off, press the select button see that OSD screen ? telling you the monitor is not dead in 1second flat;
i caN NOT understand why the HDD lamp glows,
if the PSU shuts off , most LEDs go dead, on my PC
the standby LED on the MOBO glows, unless you pull the PSU power cord.
your HP PC came with 9 different mobo, during its production run.
at least. so answers come harder from that reason.
here are some simple tests.
test 1
power on, hear fans run
does the DVD drive (or cd) button eject work,.?
do all fans not just 1 or 2 worK? look for all fans clean the lent out
or things will overheat,
PSU can be bench tested or in the PC case.
using a jumper wire, even the HP service manual covers that.
power on the PC (after keeping monitor on for 5 full minutes)
test 2
the Screen must say, "hit ESC key to enter HP setup" BIOS.
press the ESC key on the monitor
if no text shows up that is a dead PC< "text above missing{"
if the PC told you to hit another key do so.
The ESC key , activates the BIOS brain. this cause
all those pages to work as seen in your service manual;.
if BIOS is dead that is a bad PSU (monitor ok)
or CPU is overheated.
bad ram, take all sticks out and test 1 by 1, ask how. !
The PSU will shut down on up to 12 or more faults
but never shuts down the standby power bus. unless AC line pulled.
IF the PSU has fan as most do this is the first place I look.
try this guide
https://support.hp.com/us-en/document/bph06788
Jul 08, 2017 | HP Computers & Internet
HP Desktop 550-a114, will not turn on, though there is a green bright light on the motherboard
take a A+ cert course then tell this fib again.?
An LED can glow at 2vdc, tells you nothing!
only that some weak power is present, nothing more...!
learn that in electronics.
it can fail all theses ways.
good
bad.
weak
intermittent.
the PSU tests are covered here, take a volmeter
not some LED on a stick or parts glowing.
got 50 years of on the job doing this, from DC to daylight, from MIL to you name it.
http://pcdied.com/black-screen.html
Apr 15, 2017 | HP Computers & Internet
I have an asus model et27021 all in one scren goes blank and says pc no signal
If just the monitor is turn on and you see a green light or blue it might say no signal.
This could mean that the cable is not connected properly to the port in the pc.
check is the pc is powering any sounds from the power supply any lights in the front panel because is the pc is kind of dead then = no signal.
Sep 12, 2014 | Computers & Internet
ASUS CUBEX-L Nothing happens
Try checking HDD cables, clean dust particles if any.
Jun 10, 2017 | ASUS Intel 440BX Chipset CUBX-L...
Power light comes on, but will not boot, also fan doesen't come o
Without looking at it sounds like a dead motherboard. You should be able to take it to a local shop and have then check it out for about $35-$50
Dec 29, 2009 | ASUS F5R-AP038A Notebook
Computer boot problem
Temporarily swapping-in another power-supply is the first thing to try.
Don't connect the disk-drives, CD/DVD drive, nor 3.5-inch drive.
If the computer "beeps", and shows the POST (Power On Self Test) screen, then changing the power-supply is the solution.
Look at the motherboard -- any "blown" or "bulging" capacitors?
Oct 27, 2009 | ASUS A7N8X-E Deluxe Motherboard
Computer shutsdown completely when i insert my 80gb seagate barracuda 7200 HDD
What operating system are you using some can only recognize up to 10GB
and is the 80GB fitted correctly
stripe on cable to No1 pin on M/board socket and toward the 4 pin power socket on hard drive
Oct 27, 2008 | AMD ASUS A7V8X-MX ALL IN ONE MOTHER BOARD...
Asus p5p800 motherboard
seem power supply fault, because some times, it looks that power going on, it is not giving proper voltage to motherboard. check other power supply.
Oct 16, 2008 | ASUS P5P800-VM Motherboard
No signal
try taking out a gig of ram and then start computer.
Jul 03, 2008 | ASUS P5N-E SLI Motherboard
Ps3 wont start up
send it back under warranty,
The power supply may be faulty.
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
90 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
