Cd drive wont open door will open by hand but no sound or movement from drive
  • 81 Answers
Open up the side panel of the computer> and chk there should be 2 cables at the back of the cd drive> chk if both the ends of each cable is connected properly> if still it doesnt work> swap the cables with the similar cables at the back of HDD
Posted on Oct 07, 2009
How to open the fuse box on a right hand drive Honda Jazz 2011 Vitec 1.4
Most of these fuse doors have plastic ears that fit in slots so they sometimes are a little tough to get open. You most likely will have to pull a little harder in a sliding upward position. Hope this helps.
Jan 01, 2015 | Honda Jazz Cars & Trucks
My dell studio 1737 keeps making clicking sound and wont eject tried my computer, tried funtion key not doing anything please help
It sounds like your CD/DVD rom is stuck or damaged. If the drive is empty, this means that something is wrong with the drive itself.
Often, you can use a paperclip that has been bent straight to open this. insert the paper clip into the tiny hole on the door pannel of your CD/DVD drive and most of the time it should pop right open.
if it does not pop open right away, I have seen situations where the disc becomes lodged inside the case and will not allow the door to open at all. This may require you to take your laptop to a repair facility and explain the situation to them.
If you are feeling very confident, you can try to remove the CD rom drive from your laptop, remove the outer casing and see if you can dislodge the disc that way.
Aug 11, 2010 | Dell Studio 1737 Laptop
CD in stuck in the computer and I can't get it out using the eject button. How do I get it to come out?
hi,
its too simple. you dont need to worry.. Check the front side of the CD ROM. you will find there one small hole. Now just take a thing, which is around the 4 to 6 inch (min is 4") long and can pass through that hole (for eg. take medium size U pin, and remove all bends and make it straight or long needle) Now insert this equipment in that hole and press. your ROM will eject...
Hope this has helped you ... Thanks....
Jul 19, 2010 | Computers & Internet
BEO2300 intermittent CD problem
Well the power connection is simply bad soldering and easily fixed. Not to certain on the door, but it might be a drive belt that is lose or broken, or maybe more bad soldering!
Jun 25, 2010 | Electronics - Others
Cd rom door wont open
Do you see blinking light on your CD Drive. If not, you may need to check you power supply to CD Drive.
If yes, may be door looks jam, opening up once may remove any dust to smooth it out again. To open up there is small pin hole on cd drive, generally on the right side, use needle and press it through the pin hole, it will eject the CD Door and you can pull it out completely.
May 13, 2010 | Computers & Internet
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
Front door wont close properly
check the swing arms to see if they go up and down properly. They are behind the print cartridges and are attached to the plastic piece which stops the cartridges from falling inside the printer. make sure those are all guided and aligned correctly. Thirdly, if you are looking at the printer from the front, take off the side panel on your RIGHT (3 screws total--if im not mistaken) and look at the arm movement when you open and close the door. check the left side for the same movement. I've worked with a few hp 3500's and 36's, but im not a pro! just some suggestions.
Dec 15, 2008 | HP Color LaserJet 3500 Printer
My cd burner wont burn
Coleman, Sounds like a faulty drive if it opens and closes. Dontel, just because you have a CDrom drive does not mean that you can burn CD's. Is the drive rewriteable? Does it say RW or rewriteable on the door of the CD unit? Also you can click on Start/Mycomputer and see if the CD drive shows RW.
Dec 10, 2008 | HP Pavilion ze2000 Notebook
My CD Drive Is Not Opening & Not Showing To The My Computer =(
if when you push the button its led flash but not opening, turn off your computer and open its door by a needle enter and push it in the ole in center of its panel under the door. whon the door open a little use your hand and open it. if the this not solve the problem there is a hardware problem :( But if the drive dosent work at all (even the led light) maybe it's the power, then open th case left door and check th power cable... I hope this helps...
Nov 02, 2008 | Sony (CDU5212) Internal 52x CD-ROM Drive
Cassette door stuck closed
Firstly: do not think about forcing the cassette door! Look inside the unit. You need to hand rotate the capstan flywheel a bit,( a large-ish metal disc attached to the motor via a rubber drive belt.)That should release the powered deck mechanism and allow ejection. Then buy a new drive belt , so that problem does not recurr. Good Luck
Nov 02, 2005 | Aiwa NSX-A115 Shelf System
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
