I cannot get a full size picture - Televison & Video
  • 458 Answers
I assume when you try to fill the screen from a 16:9 format for example it will not fully zoom the entire screen, have you tried different screen ratios? If you are missing a large stripe of the picture then there will be a problem with one of the buffer flat cable connections, these can sometimes be re-seated into position, but more often the screen is at fault & a new screen is required
Posted on Oct 07, 2009
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Cannot see full picture mitsubishi
Look for a button on the remote that says either P-Size, Aspect, View Mode, Zoom or Ratio. Press the button on the remote to change the size to Stretch, Full etc..
www.aaatvservice.com
Jun 26, 2012 | Mitsubishi Televison & Video
New dynex 24 in tv-working good but only shows 19 in picture. How to stretch to full screen?
Go into menu with remote control & change picture size. Depending on which station you are watching you may have to change it to suit your viewing preference. They transmit in different sizes
Apr 03, 2012 | Dynex DXR24TV 24" TV
I am unable to make the screen full size when the
you need to go into the settings on the box and turn off letterbox on the picture setting.
Mar 29, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
Full tv screen is not being diplayed horzontally.
First thing to check is the picture size. You can view many program formats in a variety of picture sizes
  1. Natural
  2. TheaterWide 1
  3. TheaterWide 2
  4. TheaterWide 3
  5. Full
  6. 4:3 HD
  7. Native
  8. Dot by Dot.
The format of the image will vary depending on the format of the signal you are currently watching from you cable or satellite provider. Select the picture size that displays the current program the way that looks best to you.
To select the picture size using the remote control:
  1. Press I on the remote control.
  2. While the Picture Size screen is open, you can do one of the following to select your desired picture size:
• Repeatedly press I.
• Press the corresponding Number button (0–6) while the Picture Size screen is open.
• Press B or b while the Picture Size screen is open.
To select the picture size using the menus:
  1. Select Picture Size in the Theater Settings menu.
  2. Press C or c to select the desired picture size setting.
  3. Highlight Done and press T.
Some of the picture sizes may not be available depending on the receiving signal format from your cable or satellite provider (those will be “grayed out” in the Picture Size screen).
Second thing to check is the Native Mode which restores the size of the picture by the 3-5% that is generally lost during the normal over scanning that occurs on traditional sets. It also avoids unnecessary scaling of 1920 x 1080 HD signals. I hope this helps and good luck!
Feb 24, 2010 | Toshiba REGZA 52RV530U LCD TV
Picture size reduced - how to change back to full size
Please locate Zoom/ Picture Format button or option in Menu to adjust picture size.
If Zoom or similar button found on remote, press it repeatedly to get full screen picture.
Model and brand of your TV is not posted so button/ function name could be change as manufacturer use different labels for same fucntion.
Nov 29, 2009 | Televison & Video
Need to get pictures back to full size on my computer.
Go into the menu and try to find an entry referring to picture quality. Choose the highest setting.
Nov 17, 2009 | Vivitar ViviCam 3315 Digital Camera
It shows picture not in full screen like the movies black screen at top,in middle is the picture,black screen at bottom
If this happen on DVD's it is because the DVD is formated to Widescreen, 16x9 size, your TV is 4x3 size. Unless the Menu has an option of Picture size, or Format, to set to Full screen. there is nothing you can do other than be sure to check the DVD for picture format size before purchasing.
Sep 28, 2009 | Hitachi 43F300 43" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
