Question about Broan-NuTone N-LS100SE Exhaust Fan Exhaust Fan
Have a broan n688 ceiling exhaust fan in bathroom and now it takes a couple of minutes to actually start, finally making a whirring noise before coming on. Solution?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 72 Answers
First turn the power to the fan OFF. Take it down from the ceiling by removing the screws holding the cover on. Then remove the screws holding it to the ceiling. Then unscrew the screw caps that twist (connect) the wires from fan motor to the house wiring. Do a general clean up on the fan. Use an old paint brush to get in the hard to get at places. Rotate the fan by hand. If it does not rotate freely, put some oil on the shaft where it goes into the motor, and put some on where the shaft comes out the back. If it still does not rotate freely, buy a replacement and install it.
Posted on Oct 07, 2009
Old NuTone 9093n Model replacement.?
Hi -- I just spent a couple of days taking out the old assembly, cleaning all the parts (layers of dust coats) and putting the 9093N back in order to fix the noisy fan. The cold air coming back in is from to the heating and I'd guess the heating element is busted. Yes, you can run it in both airflow modes: ceiling air exhaust and hot air blown to the floor. That said, the noise level on mine hasn't gone down. So I'll look for the replacement assembly. Good luck!
Mar 23, 2013 | Broan-NuTone Dryers
Nutone bath fan how do you clean the vent
Usually the vent cover pulls straight down, and is held in place with 2 V-shaped metal spring wires.
Squeeze each spring wire together to release cover from ceiling box.
Use vacuum to clean vent fan housing. Some vent fans can be disassembled and motor housing removed for cleaning. Do NOT use water on electric motor. Simple vacuum, or dry toothbrush cleaning is good enough.
Spay tiny bit of WD40 on the fan motor shaft or add tiny dab of white grease if desired.
The plastic cover can be scrubbed with soap and water, rinse to remove soap residue, and when dry, paint with aerosol spray paint using 3-5 very light coats applied in 5 minute intervals.
Jul 28, 2012 | Broan-NuTone Fan,Bathroom Exhaust Broan...
My bathroom Broan exhast w/light makes a constant clicking / tick tock sort of noise when the fan is not running. as soon as I turn the fan on the noise stops and then stops after I turn the fan off, only...
remove the cover and clean anything in the vent , check the fan for anything that could be touching it, as the back draft comes through the vent, something could just be touching the fan blade as this draft makes the blade turn slowly, which would create a ticking noise
Jul 10, 2011 | Broan-NuTone (8663RP) Ceiling Fan
My bathroom exhaust fan has a dial timer. Sometimes lately the fan does not come on for a couple of minutes after starting the dial timer. Is that likely to be a problem with the dial timer, or with the...
This could be the timer or the motor. The timer could be going out or not starting up in the right position. Has anyone worked or removed the timer knob, it could have been put on just a little off causing the switch to be off just a bit. Again the motor could be going out,such as the bearings inside. I would see what type of warranty is on this fan. I know these exhaust fans can get a little pricey, so I would see what warranty options I have.
Mar 06, 2011 | Broan-NuTone Fan,Bathroom Exhaust Broan...
Problems with exhaust fan NuTone Model LS 100SE
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
I have a thermador bathroom ceiling heater fan. Where can I get a replacement?
Amazon.com: bathroom ceiling heater Broan Product Detail
If you have the old Thermador ceiling type of heater that must be mounted on the ceiling surface there aren't many choices. Only the Broan-Nutone 154 & 157 models. The 154 @ $37 didn't seem to last too long but it's 1/3 the price of the radiant 157 model at about $100+ dollars. The radiant model may last longer
Sep 02, 2009 | Heating & Cooling
Bathroom fan
You'll be able to access the motor to service it and the wiring junction box from inside the bathroom. Please rate this answer if it was at all helpful.
Jan 31, 2009 | Broan-NuTone Designer 721 Ceiling Fan
Noisey 8 x8 Broan Bathroom Exhaust Fan (With Light) (7 years old)
Mine was doing the same thing. I found it was coated with dust.
I took the blower out [unplugged it, and removed the single screw holding it to the box], took the face plate off [removed 4 or five screws] brushed the squirrel-cage fan blades using a narrow, long and stiff bristled brush, and reassembled it [used care to align the small plastic axle on the flap valve ] and reinstalled it. The vibration was greatly lessened and the fan was about as quiet as it had ever been.
Dec 23, 2008 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Broan-NuTone N-LS100SE Exhaust Fan Exhaust Fan Logo
422 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
