Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Hi, I have a Wurlitzer 3600 Superstar that I am working on. I am having trouble figuring out why the carousel won't stop spinning. It is looking for it's "Home" position, but won't stop. If I select a record it will find it and play it without issue. But when it returns the record, the carousel just spins and spins, never stopping at it's home position. As it passes what I would assume to be it's 'home' position, I can hear a light click, and then carousel carries on. Any hints?
    Champion:
  • Wurlitzer Expert
  • 211 Answers
Look at the switch and solenoid assembly at 1 oclock on the carousel. That is what activates to set it going and it then clocks off a ratchet wheel to do two full cycles looking for a selection then stops. If it gets stuck the carousel wont stop.
Posted on Oct 28, 2009
MR. CHRISTMAS CAROUSEL WON'T TURN
I realize this post is way old, but wanted to thank LtJim for his description on how to take it apart.
It turns out the reason mine was not spinning is that one of the plastic mechanisms that make the horses go up and down (located under the main piece that comes off with LtJim's directions) had partially broken and that horse would go all the way to the bottom and then the carousel would stop spinning.. There was no way to fix the plastic, but by holding the horse up with zip ties hidden under the top got the thing to work again. Thanks again!
Dec 12, 2012 | Toys
Repeats selection and won't chage seletion. superstar 3600
Obviously your channel display must be working. I would assume the radio has sustain some harsh trauma to the channel selector itself possibly a drop.
Remove the speaker side cover looking down on the channel selector and its pcb board check connection and between the mechanical switch and pcb.
This may be as simple as a cold solder joint the problem is finding it.
http://www.cbtricks.com/radios/superstar/3900/graphics/ss3900_sch.gif the schematic is for the 3900 which i believe are similar units.
Oct 24, 2011 | Radio Communications
Wurlitzer 3600 Jukebox turntable problem
The 3600 has a hub that is supposed to play dinked and undinked records. They had 33rpm and 45 rpm records back then, so to change the record speed the undinked (small hole ) records pushed down the hub flat when it landed on it, which changed the gearing. When a dinked (big hole) record lands on it falls onto the larger part of the hub. So if the hub is down and stuck there that's your problem. After the hub has been pushed flat (because of a small hole record) it is supposed to rise up again when the record is returned to the carousel. Have a look under the turn table and push up the centre rod.
Dec 20, 2009 | Wurlitzer Jukebox 1015 One More Time...
Rock-ola 498 Carousel Spins Continuously
Look on Ebay for manuals or try at www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Sep 02, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 series wont select a record ?
If the buttons don't latch in, the machine is not in credit. Put on free play or put some money in.
Dave F.
May 30, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer CD1015
Your problem is usually caused by a faulty CD player or a faulty CD control pcb (under the CD player).
The leds Z and M on the credit unit only flicker when the carousel turns.
Aug 05, 2008 | Wurlitzer Jukebox 1015 One More Time...
Cd wheel spining non stop
ITS NOT THE WHEEL SPINNING ITS THE LASER ITS TRYING TO READ THE DISC THAT CAUSE IT TO SPIN FAST AND SLOW FAST AND SLOW YOUR LASER NEEDS A CLEAN
Jun 27, 2008 | Wurlitzer Jukebox 1015 One More Time...
The microswitch at the base of the gripper arm is what enables the scan motor when the gripper is over the carousel. You will probably find that the small lever on the base of the tone arm is not clicking the microswitch properly.
Dave .
May 20, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 OMT Disc spins, then stops....
When the disc is taken from the carousel and put on the player how long does it take for it from the time it is placed onto the player to being returned to the carousel? Also is the cd spinning when its on the player or not spinning at all. The answers to these questions should help in pinpointing the actual problem.
Mar 16, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
518 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
