Question about eMachines T3656 Celeron 440 1GB DDR2 160GB Intel GMA 950 Windows Vista Home Basic PC Desktop
I'm upgrading my graphics card and I can't figure out how to take the side panel off so the monitor plug is outside the computer
    Problem Solver:
  • 6 Answers
Depends. If there is no screw holding the plate then you must snap it off.
Posted on Oct 07, 2009
How do I stop screen flickering
If this occurs within a specific application, it probably has to do with the fact that the application wasn't programmed for double buffering. If your screen is constantly flickering no matter what, it could be bad video drivers. Try updating them. If that fails, it's probably either bad hardware. Try a different video card. If it still persists, it's a bad monitor.
Sep 12, 2014 | Microsoft Windows Vista Home Premium with...
USB 3.0 upgrade
You might need to upgrade you graphics card.
USB 3.0 is the newest connection port upgrade, arriving on the market in 2010.
The cable port connection is far superior to the USB 2.0 port, as it is able to transport up to 5 gbps (gigabits per second), instead of the previous version's max speed of 480 mbps (megabits per second).
However, most computers do not yet have this connection port installed, in which case you are left to upgrade your own computer system to the newer, faster connection method.
Turn off your computer, then disconnect all of the cables running into the computer.
Remove the Phillips screws from the back side of the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
This unlocks the case, allowing you access to the interior of the system.
Slide open the computer case.
Inside the middle is a longer circuit board.
This is the motherboard of the computer.
On the back side of the motherboard, facing the rear of the computer, are PCI card slots.
These allow you to install additional hardware onto the computer.
Slide the USB 3.0 connection port into one of the open PCI card slots, then push down the plastic levers along each side of the slot to lock the card into place.
Close the computer cover, then tighten the Phillips screws and reattach the cables.
Power on the computer, then insert the driver installation CD into the disc drive of the computer.
Once the installation wizard loads, follow the prompts of the wizard to install the drivers.
Restart the computer once finished and the USB 3.0 connection ports are ready for use.
http://www.pcworld.com/article/186566/usb_30_finally_arrives.html
Compatible graphics cards for Gateway Computers
Just as a processor handles data and a sound card outputs sound, your computer's video card is responsible for processing graphics and displaying them on your monitor.
The video cards manufacturers build into computers typically have enough power for the average user, but it may be necessary to upgrade your video card for better performance in games or graphics heavy applications.
Understand which types of video cards are compatible with your Gateway computer and learn about all your options.
PCI Express Graphics Cards
Many newer Gateway computers have a Peripheral Component Interconnect (PCI) Express slot in which you can add any PCI Express compatible video card.
These devices range from budget cards suitable for everyday tasks to high end models for gaming that cost hundreds of dollars.
AGP Graphics Cards
Older Gateway computers likely have an Accelerated Graphics Port (AGP) slot for AGP compatible cards.
The AGP bus provides sufficient bandwidth for high performance graphics cards, but the technology is no longer in use and AGP cards are difficult to find.
PCI Video Cards
Nearly all Gateway computers should have at least one PCI (Peripheral Component Interconnect) slot regardless of age.
This slot has enough bandwidth to support a wide range of peripherals like sound cards and modems, but is not suitable for high end video cards.
You can find a number of low and mid-range cards for PCI slot computers, however.
USB Video Cards
USB video cards are also compatible with Gateway computers sporting USB 2.0 or USB 3.0 ports.
These external cards sit outside the computer and allow you to connect additional monitors to your system.
They are a good option for people who feel uncomfortable working inside computers.
http://www.pcmag.com/article2/0,2817,2371083,00.asp
How to buy a video card
http://support.gateway.com/us/en/support/default.aspx
Gateway Support
Upgrade My Video Card on My Gateway Desktop
Gateway desktops are affordable computers, but they often do not come with top-of-the-line video cards.
Computer games may run slowly or not at all on your Gateway desktop.
One way to solve this problem is to upgrade the video card.
Video cards come in PCI, PCI-E and AGP interfaces, so you should be able to find a video card upgrade no matter what Gateway desktop model you have.
Click "Start" and right-click "My Computer."
Select "Properties" from the menu that appears.
Go to the "Hardware" tab.
Choose "Device Manager."
Click the plus sign next to the Device Manager entry listed "Display Adapters."
Find your graphics card in this list.
Double-click it.
Go to the "Drivers" tab and click "Uninstall Drivers."
Click "OK" to confirm the uninstallation process.
Shut your Gateway desktop down.
Pull the power cable out of the back.
Look at the back of the Gateway computer tower for screws on the right side panel or on top of the case for a cover release handle.
Nov 29, 2013 | Gateway DX4200-09 PC Desktop
ASAP! Power Problems. Please Help!
try replacing the cable first, or try a diifferent monitor, otherwise open the case and look for a card that has the vga(monitor plug) on it-but your existing one may be built in to the MOBO in which case you will have to disable that driver, then pop in your graphics card in an empty pci slot and download a new driver
Sep 05, 2009 | HP Compaq Presario SR1420nx...
What do i do if my computer monitor goes blank and turns on and the cords are all the way plugged in...is it the tower or monitors problem??
Hi There !!
Thank you for writing to Fixya.com
The monitor turn off & tun back on automatically, are the symptoms of Faulty Driver for graphic card, or Faulty Graphic Card & even could be the monitor it self. My suggestion would be to first, Uninstall & reinstall the drivers of the graphic card. If still problem persist you might need to replace the Graphic Card. But 80% of the times, drivers causes these kind of issues.
Steps how to change the Graphic Card:
  1. Static electricity can seriously damage the components inside a computer. To avoid this you must ensure you are grounded when operating inside your computer. One way to do this is to purchase an anti-static wrist strap which you should wear at all times. The wrist-strap plugs into an electrical socket which will automatically discharge the static electricity in your body.
  2. The graphics card or video card translates information into the graphics and text that appear on the monitor screen.
  3. Most motherboards now include a slot specifically designed for the graphics adapter called the AGP slot. This stands for Advanced Graphics Port.
  4. Modern graphics adapters usually incorporate some memory right on the card to improve their performance.
  5. To get into the tower you will have to remove the panel which is on the right hand side when viewing the tower from the back. Open this side of computer case by removing the screws at the back of the tower which are holding it in place. Then simply slide the panel off.
  6. Locate the old card on the motherboard and remove it by firmly lifting it out of the slot it occupies. Insert the new card, ensuring it is firmly pushed into the slot. Note: Some AGP ports have sliding locks that hold graphics cards in place. If your card is reluctant to come out or won't stay in, check if your port has these. If it does, use a screwdriver or your fingers to pull it to the right (open) or left (close). Make sure it clicks before removing or adding the card to minimize the risk of damaging the new card or your motherboard.
  7. Replace the tower's side panel, switch the computer on and install appropriate software that came with the new card.
Hope all these steps will help.
Regard's
Anurag Shukla
Sep 03, 2009 | Microsoft Windows XP Home Edition
Monitor wont work
You were not very clear with your question. If you mean you have disabled your onboard video, then installed the new video card and get nothing then the card is not compatible with your system OR you got a bad card. If you mean you simply installed the card, turn on your computer and get nothing until you move your monitor plug back to the original port (without turning off the computer) then you must disable your onboard video by going into your BIOS settings. Follow the instructions that came with your video card or your computer to do that. Usually you get in by pressing delete or F2 while the computer boots.
Jun 06, 2009 | Evga e-GeForce 7300GT 512MB Graphic Card
Dell C521 Where to connect monitor?
This means that you have an external video card (which is not outside the computer). This video card will be plugged into the motherboard. That message is saying that the port on the back of the computer that your monitor is plugged into is the wrong one. You need to look for another port on the back of the computer.
Here is a picture of a VGA port that you should use if you have a VGA cable to connect the monitor (Blue Ends).
http://news.softpedia.com/images/reviews/large/VGA.jpg
Here is a picture of a DVI port that you should use if you have a DVI cable to connect the monitor (White Ends).
http://zedomax.com/blog/wp-content/uploads/2008/09/dvi.jpg
So depending on the cable and connections that are available on your computer and your monitor depends on what you have to use. I hope that wasn't too confusing. Let me know if you need more info.
Feb 12, 2009 | Dell Dimension C521 PC Desktop
I just bought a 28 inch viewsonic screen and the only resolution it lets me see my entire desktop is 1088x612. Otherwise it cuts off all four sides and I can't see the start menu... please help!
You didn't list the graphics card you are using, but from your description of the problem, the monitor has a higher resolution than the graphics card can support (usually 1440 x 900, some are higher resolution)
Generally, the solution if to upgrade the graphics card, if the graphics in your system isn't easily upgradable, then you may need to upgrade to a system with adequate graphics
Dec 07, 2008 | Computers & Internet
Blurred pictures on monitor
The problem is not the monitor, it is the display adapter (Video card) of your system needs a valid Vista driver. (NVidia, ATI and Intel are the 3 largest Graphic card manufacturers) Monitor drivers are almost never needed except on some advanced large LCDs.
You said up upgraded to Vista, did you use a Vista upgrade DVD or just perform a clean installation of Vista? Have you installed Vista Chipset drivers? The chipset and Graphics drivres may not be native to Vista, you may need to install them.
Jul 05, 2008 | Proview PL926WBi 19" LCD Monitor
New monitor but unable to use its maximum resolution settings
no, there's nothing wrong with either your graphics card & monitor.. it just that your graphics card does not support a 1680x1050 resolution. if you want to fully enjoy the resolution of your monitor, you should upgrade your graphics card. purchase at least 256mb graphics card and you will see the difference..
Jan 21, 2008 | Gateway FPD2275W LCD Monitor
eMachines T3656 Celeron 440 1GB DDR2 160GB Intel GMA 950 Windows Vista Home Basic PC Desktop Logo
66 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
