Question about HP LaserJet 4 plus Printer
Paper jams and folds into accordians - HP LaserJet 4 plus Printer
  • 105 Answers
Most problems with the HP4 series can be fixed by replacing the paper pick roller. Is your paper jamming at the output slot on the top? Can you print ok with the back door open? If so, you need a new output assembly. Try Feedroller.com for cheap parts.
Posted on Oct 07, 2009
Paper jam before printing process
more than likely your fuser is not turning the gear may be bad on the fuser or an internal gear.
Jun 30, 2014 | Sharp Mx-4111n Multifunction Copier
Paper jam in back, accordian fashion, cannot extract lexmark e328
There might be a access door in the back of the printer, remove the door and gently pull the paper out.
May 26, 2010 | Lexmark E322 Laser Printer
The screen reads paper jam error, but there is no visible paper jam and when turned on a grinding noise occurs
Most likely, there is a paper jam in the fuser unit....which is stalling the fuser rollers, thus causing grinding noise (accordian or fan folded jam)
Oct 24, 2009 | Canon imageCLASS D320 Digital Copier
My printer folds the paper in the back accordian
check the drum unit and toner unit, also check on all rolls inside the printer.
if still not working you can send it to me to fix it for you.
Jul 13, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper jam repeatedly
Possible cause:
The eject rollers get too slippery because of paper dust and other foreign matter.
Recommendation:
Clean the eject rollers with a paper towel dampened with water. A second cleaning may be
necessary. The easiest way to do this (without disassembling the machine for full access to
the rollers) is to hold the dampened paper towel against the rollers and make a blank print.
Clean the rollers as they turn and remove the paper towel as the paper ejects. Repeat as
necessary.
Now is a good time to also clean the paper pick up roller and feed rollers to prevent
feeding problems.
Jun 18, 2009 | Brother HL-2070N Laser Printer
Brother 2820 constant paper jams
Most likely the fuser is worn out, and needs replacement
Jun 02, 2009 | Brother IntelliFax-2820 Laser Fax
Paper is jamming when I print something
Were you able to remove all of the original jammed business cards? where the leading edge of the "Fanfold" prints occurs, you will probably find something blocking the paper path. HP printers usually have a limit on the paper weight that the printer can handle when doing duplex (2 sided) printing. Check this against the weight of the cards you are printing.
Apr 18, 2009 | HP Color LaserJet 2600n Printer
Paper prints halfway but jams at top roller
hi,,
maybe your fuser assembly is in lack of silicon paste that's why you are experiencing paper jam..
just try to apply a silicon paste it will run in smooth again...
Oct 30, 2008 | HP LaserJet 4L Printer
HP LaserJet 4 plus Printer Logo
240 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
