LG flatron L1710S PC Monitor
Graphics chip faulty causing picture roll on start, I've been told chip is an integrated part of the circuit board and cannot be replaced separately, is this true ?
Regards
Stan
  • 70 Answers
Depends on what motherboard you are using. IF this is indeed the case, you can still put a CHEAP add-on graphics card on the motherboard and get the system up and running with minimum expenses. Most motherboards support adding an additional graphic card besides the onboard chip.
Posted on Dec 24, 2007
Power on power led blinking
Hello.
The LED blinking light usually means that the attached PC is not powered on or the VGA connector (end of cable connected from the monitor to the PC) on the monitor, the cable or the VGA port on the PC is faulty.
Try your monitor on another computer. If it works, there is a problem with your PC. If it doesn't work, the VGA connector, the monitor's VGA cable or the monitor itself, is faulty.
Hope this helps.
Jan 23, 2011 | LG Flatron L1710S 17" LCD Monitor
My monitor won't turn back on after a reboot, no on light, worked fine prior
check with the power cable or the video cable is connected correctly in the motherboard VGA or if you have graphics card connect the video cable of the monitor to the graphics card VGA slot.
Oct 20, 2009 | LG Flatron L1710S 17" LCD Monitor
My lg flatron l1710s flashes on and then the picture goes out and thats it but the power light stays green
This is highly suggestive of a power supply failure to deliver the voltages required. A new power pcb should fix the problem but is a job for an experienced repairer.
Sep 24, 2009 | LG Flatron L1710S 17" LCD Monitor
My Lg Monitor wont show screen (Power Button Flashing)
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
May 04, 2009 | LG Flatron L1750S 17" LCD Monitor
Monitor light blinking
  • Video cable.
  • Motherboard.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Jan 17, 2009 | LG Flatron 775FT 17" CRT Monitor
Contrast
The supplied software should allow you to set brightness and contrast if there are no front panel buttons to set it.
Check for LG or Flatron programs under the Programs listing available from the Start panel.
Jun 19, 2008 | LG Flatron L1710S 17" LCD Monitor
LG Flatron L1710S Monitor stuck in Power Save Mode
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
Jun 02, 2008 | LG Flatron L1710S 17" LCD Monitor
Computers & Internet Logo
418 people viewed this question
Alun Cox
David Payne
David Payne
