Question about Brother MFC 8840D All-In-One Laser Printer
Printer says DR mode in use what does this mean
  • 37 Answers
DR Mode means distintive ring. This is if you are using two or more phone numbers on one line. For example, you could have your voice mail number and your fax number on the same line, but when a call comes in to your voice mail the fax will recognize the ring pattern and won't pick up the call. If it is truly a Fax, then your fax will pick up the call by recognizing the ring pattern.
Posted on Oct 09, 2009
Dr Printer error Unable to connect to the server
Dear
You can use EPM(easy printer Manager) or smart panel. These files can down loaded from the samsung site. install and run in the PC it will show the status of the printer.
The red light blinks and printing is possible means get ready to replace the toner cart. with a new one.
Thanks. Printer Support SAMSUNG India
Apr 25, 2012 | Samsung ML-2510 Laser Printer
My brother mfc6490cw says dr mode what is this
DR stands for distigntive ring.
Before you are able to change the receive mode, you will need to turn off DR.
To turn off DR press MENU, then the down arrow until FAX and press OK. Then with down arrow choose MISC and press OK. Then with down arrow chose DISTINGTIVE and OK, then down arrow until OFF and press OK.
Jun 06, 2010 | Brother MFC 210C All-In-One InkJet Printer
Intellifax 2820
DR mode means that the distigntive ring feature has been activated so it will not let you change receive mode. You need to turn off DR first. Press menu/set then 2, 0, 2, then press the down arrow till you see distigntive off then press menu/set.
Now you should be able to change the receive mode to fax only!
May 29, 2010 | Brother IntelliFax-2820 Laser Fax
Can't set mode to receive fax, read through manuel says DR mode in use. fax does'nt pickup when a fax or call comes in stuck in manual.
DR MODE is in use means that your machine is setup with the distinctive ring feature, to turn it off follow the directions below.
Turning off the Distinctive Ring
1 Press Menu/Set, 2, 0, 2.
2 Press ▲ or ▼ to select Off.
Press Menu/Set.
3 Press Stop/Exit.
Then you will be able to change the receive mode.
Apr 16, 2010 | Brother MFC 210C All-In-One InkJet Printer
Fax is stuck on manual mode. how can I change. When I try to change modes, is says that DR mode in in use.
I had this problem too, I just fixed it! DR = DISTINCTIVE RING, this means you have it turned on. To turn it off go to menu, fax, miscellaneous, distinctive and select OFF. Now go to back to initial setup and select your mode!
Mar 03, 2010 | Brother MFC-440CN InkJet Printer
In tally 7.2 when we enter the voucher the Cr or Dr is not seen
hello user of tally,
you are getting ur voucher in single entry mode so when u entered in to a payment/receipt/contra press F12 and say NO to the following option
"Use Single Entry mode for Payment/Rcpt/Contra" :- No
Jul 01, 2009 | Tally T6218 Matrix Printer
MFC 465 CN - says FAX in DR Mode...What is that?
DR mode is distinctive ring, you have to go into fax setup and step through the options. If you go to print reports and select user settings the report will tell you what it's set for and the options are found in the same order they are printed.
Jun 24, 2009 | Brother MFC-465CN InkJet Printer
WHAT IS DR MODE AND HOW DO I TURN IT OFF
DR Mode is "Distinctive Ringing". You can turn it off in the menu (Menu -> Fax -> Other, if i recall correctly).
Jun 04, 2009 | Brother MFC-465CN InkJet Printer
Mfc 8460n dr mode in use
The message DR mode in use or BT Call Sign On will appear on the display of the Brother machine if you attempt to change the receive mode from Manual to another mode when the Distinctive Ring feature (BT Call Sign) is turned ON. If you want to change the Receive Mode, set the Distinctive Ring feature (BT Call Sign) OFF.
  1. Press Menu or Menu/Set.
  2. Select Fax => Miscellaneous or Tel Service => Distinctive or BT Call Sign.
  3. Press the Up or Down Arrow key to select off. Press OK or Menu/Set.
  4. Press Stop/Exit.
Jul 16, 2008 | Brother Office Equipment & Supplies
Fax will not recieve
DR mode means that Distinctive Ring is set to on which will force your fax machine to manual receive. Turn DR off and you can set it to whatever mode you want.
Nov 03, 2007 | Brother FAX-575 Plain Paper Thermal
Brother MFC 8840D All-In-One Laser Printer Logo
871 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
