Question about Craftsman Garden
My craftsman leaf blower will not start, its firing, getting fuel. will not start even if you put gas in the sparkplug hole
  • 437 Answers
It sounds like the engine is worn out. Have you done a compression test on the engine? If it is not at least 100 psi, the engine will not try to run.
I would get a compression test done on the engine, then take out a loan and go get you a commercial grade blower.
Good day.
Posted on Oct 07, 2009
    Problem Solver:
  • 5 Answers
THE ENGINE WILL NOT RUN WITHOUT GOOD COMPRESSION. IF SOMEONE PUT JUST GAS IN THE ENGINE IT HAS TOOK OUT THE RINGS AND THEY WILL BEST STUCK .
Posted on Oct 02, 2012
Just wont start got getting fire and gas still wont crank even if i put a little gas on sparkplug
Pull cap check to make sure you are firing in seaquance you may need to put the number 1 up and check to see if the number 1 is is firing number 1. It's due to someone not setting the timing properly
Sep 11, 2012 | Poulan 25CC Gas BlowerVac
I've put a new sparkplug and new filter -but the blower won't start . Doesn't even feel like it wants to start
Put a spoon full of gasoline straight down the plug hole. Reinstall the plug, if it starts then you obviously have a fuel problem. You may need a new kit installed in the carburetor. Easy fix.
Nov 17, 2010 | Craftsman 4 Cycle Blower/Vac
Leaf blower will not start i have spark
try putting a little gas in the plug hole, like a spoon full only, if it fires on that , then you obviously have a gas problem. You may need a little carb work, such as a new kit installed.
Nov 17, 2010 | Craftsman 27cc 2Cycle Full Crank Curved...
I have a craftman leaf blower model#368794963 hand held 25cc it was running fine but now it wont start
hello
if you have spark remove the sparkplug and priming the engine(put some gas in sparkplug hole into the cilinder).Pull the rope for starting engine as many times as you need until the engine starts but without any choke and the switch on the on position.Please let me know what is going on.
regards savumihai71
Nov 04, 2009 | Craftsman Garden
Won't start
May have moisture in the fuel. Try draining the old fuel out, put in new, add Stabil, or some other fuel stabilizer, clean & gap plug. Should start.
Oct 31, 2009 | Craftsman 4 Cycle Blower/Vac
I have a 25cc Craftsman Blower/Vac model 358.794941 which will not start. I have replaced the spark plug and carburetor. This is 2 years old and not even 10 hours on it.
hi
if you have compression and spark(a blue one) try priming the engine,put some gas in the sparkplug hole and start the engine.if it fires only the gas you putted inside there is a delivery problem to find and fix(carburator and hoses.
bye
Oct 05, 2009 | Craftsman Garden
Can't get snow thrower to start
Does it have spark ??? I would check that first, and IF it does maybe add a tablespoon of gas down the sparkplug hole then try it..
Dec 30, 2008 | Craftsman 4 Cycle Blower/Vac
Crafsman gas blower: fuel lines to primer bulb had to be reconnected; now blower won't fire at all. Replaced plug and made sure it sparked; still nothing when I try to start.
Hi
Priming the engine(put some gas in the sparkplug hole ,after you have checked the sparkplug,the colour of the spark has to be violet).Start the engine.If it starts there is a carburation problem,change the fuel lines to primer bulb.
wish you good luck savumihai71
Dec 04, 2008 | Craftsman 4 Cycle Blower/Vac
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
337 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
