Question about Metabo DH316 13-by-6-1/4-Inch Portable Thickness Planer
I threw out the owners manual - how do I change the blades?
    Brigadier General:
  • 3,614 Answers
HI
release the blade keeper and tap it lightly to slide out the blade. Fit the new blade, aligning it with the base plate using a straightedge. Tighten screws and manually rotate the blade drum to check it spins freely.
Posted on Oct 07, 2009
Changing blades
need mechanic for that cos need to order 2 special blades
Apr 02, 2016 | Sewing Machines
Can I change the knife blades or do I have to take it into the shop? It has stopped cutting cleanly, causing the cut part to wad up as I serge.
Usually, the owner can change one of the blades, but it is generally recommended the other blade be replaced by a professional technician. Consult your owner's manual as it should explain which blade can be replaced by the owner.
Feb 17, 2016 | Sewing Machines
Machine does not trim
Consult your owner's manual. Make sure the upper blade has not been raised, ie for cleaning. If the blades have knicks or have been used for quite some time, it could be time for replacement. Usually, one blade can be replaced by the user, but the other should be installed by a knowledgeable technician. The owner's manual should have some instructions about changing blades.
Jan 02, 2016 | Sewing Machines
Northern Tool 10" compound miter saw. How do I change the blade?
remove the power cord from the socket in the wall first
if there is a small hole in the blade , place a phillips screw driver in that hole and turn until the driver is locked against the depth guard
use the correct size spanner /socket and undo the spindle nut holding the blade on
if there is no hole ,then place the screw driver in the teeth of the blade to lock it
the motor will spin so that the teeth cut against the direction of cut ( up into the guard or up through the depth guard ( blades normally have a arrow for rotation direction)
tighten the spindle nut and if no hole in the blade use a hammer and hit the spanner with a hard rap
Sep 30, 2015 | Saws
How do i change the blade on a power max table saw model # 82.752
A delicate operation you need to find your owner's manual. There should be special tools to remove the nut and hold the blade. Please be careful. make sure it's unpluged before you try anything. No owner's manual? Google Make and model. You may find instructions. Youtube may have instruction video.
Feb 27, 2015 | Saws
New blade tares threw the wood. its hard to push the wood threw the blade
Are you using a new band saw blade? Are you running on a correct speed. I suggest to change the blade. I got 201 Carbon blade from http://sawblade.com/ . Also, make sure you're in right speed so that the blade will make the cut. Don't feed it so hard, let the blade do the work.
Jan 27, 2014 | Ryobi 9" Band Saw Model Bs903
I have a makita JR3000VT recripricating saw, i dont know how to change the blade in it
Hello. Here is a link to the product manuals. pg 7 of the owner's manual shows a decent visual on changing out a blade. Hope this helps.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=243
Apr 05, 2011 | Garden
What size blade fuse would I need for my D800.2 Boss amplifier? I took it to a shop to work on my music system ,and for some reason they threw away the fuse. I don't remember what size was in the single...
You need a 30 amp fuse according to Boss Audio's owners manual.
http://www.bossaudio.com/support/index.php?_m=downloads&_a=viewdownload&downloaditemid=564&nav=0,2
Aug 02, 2010 | Boss AUDIO SYSTEMS D8002 Car Audio...
Change the blade on my porter cable 347
Here is the owners manual for your saw. It details the procedure for removing and installing a blade.
Please rate this positive if it helps!
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/En900003.pdf
Jul 03, 2009 | Porter Cable Cable 7 1/4" Quik - Change...
RYOBI TS254 change saw blade???
should have blade lock button remove blade with proper size wrench reinstall new blade in reverse remember some of these the loosening of the blade will be clockwise so if nut dont come loose try clockwise to loosen good luck
Apr 22, 2008 | Irwin Miter Saw Laser Guide Attachment...
Metabo DH316 13-by-6-1/4-Inch Portable Thickness Planer Logo
105 people viewed this question
Top Metabo Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Metabo Craft and Hobby Expert? Answer questions, earn points and help others
