Question about Neff W4380X1 Front Load Washer
Spinning Hi, when I put a load in, my machine will get all they way through teh cycle but will not spin - I don't think it is able to drain properly as evrytime I open it to check how dry it is, there is a puddle of water in the machine.
  • Anonymous Dec 24, 2008
    where is the filter orthe pressure switch
  • mcdodd Dec 24, 2008
    my is a top washer it will not drain or pump where is the filter
  • 139 Answers
The reason why it aint spinning is because it is not draining. All new washing machines have what you call a pressure switch that can tell if water is present in the machine.. if present it will not spin.
your problem is either you have a blockage in your filter (5 min job) or you drain pump is not working properly
hope this helps merry christmas
Posted on Dec 24, 2007
Spin cycle not working properly. A little water (1 inch) is left and clothes are heavy with water. I tried the spin cycle repeatedly - water still at bottom of tub.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Maytag Centennial MTW5800TW Top Load...
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
heatman101
Jun 25, 2011 | Washing Machines
Washer does not spin out during the spin cycle. Everything else is working properly.
heatman101
Apr 14, 2011 | Washing Machines
My washer seems not to spin properly during the rinse cycle and will not spin now i get what i assume is an error message ue when its time for the spin cycle to begin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 18, 2011 | LG WM2455 Front Load Washer
Washer fails to remove water from clothes after rinse and spin cycles are completed. M/N 110.26732500
'f its a top load put something down in lid switch hole.....Start wash cycle let unit go through cycle by itself Don;t touch timer unit should fill then adjatate then drain then you will here a clunk and unit will spin thats the wash////then unit will fill then adjatate then unit will drain(this is the inportant part ) unit should drain completely before it spins if it is spinning with the water in it your gearcase is getting bad//This condition also put stress on the clutch//if unit is not draining and spinning at the same time but just spinning slowly then you will need a clutch.....Hope this helps if i did help you please vote need more help please ask..........
Feb 03, 2011 | Kenmore Washing Machines
My AWG 320/2 doesn't seem to be draining away the water properly at the end of a cycle. Any idea what the problem might be.
heatman101
Jan 23, 2011 | Whirlpool AWG320 Front Load Washer / Dryer
My washing machine is not draining properly, even when I set it to the drain and spin cycle.
heatman101
Sep 17, 2010 | Maytag EPIC MFW9700S Front Load Washer
Won't drain and spin. Cycle completes and all the lights on far right flash. Door won't open. Bottom of washer is filled with water. Tried putting it on drain and spin cycle. Still won't drain. Beeps...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Frigidaire Washing Machines
Repair front load washer
wash machine not draining properly at end of wash. not fully spinning.
pls advise
Sep 11, 2008 | Washing Machines
Drain & Spin issue
Have you checked your water pump? Sometimes this is an issue of the strainer being plugged as well. Do you get any flashing error messages on teh screen?
Jan 14, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Neff W4380X1 Front Load Washer Logo
344 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
