Question about Haier AHD50 Dehumidifier
Water leaks from the bottom front under the bucket. Haier HD 308
Water leaks from the bottom front under the bucket. Bucket does NOT leak.
2 Suggested Answers
SOURCE: Water leaks from the bottom front under the bucket.
Try cleaning the filter first. Wash it with water and let it dry overnight. Then make sure no debris is blocking the inside of the spiggot which fills the pan. The spiggot can get blocked by dust anddebris or insect webs. Clean thoroughly with a rag and your finger.
Posted on Oct 08, 2009
Why is my Frigidaire dehumidifier leaking water from the bottom of the unit?
Hi friend, thank you for your post!
I have identified that a few possibilities to why water is leaking from the bottom of your dehumidifier could be a crack inside your bucket or condensation from the bucket. I would remove your bucket and look it over to see if you can locate any visible cracks or chips. How much water is leaking from your dehumidifier? If you can provide any further information I look forward to assisting you. -Matt
Sep 03, 2014 | Dehumidifiers
I have a Haier dehumidifier, model DE45A-L and recently it has started leaking water and not collecting in the bucket. When we dump the water out it seems to just come from everywhere in the front. The...
There may have been a failure in the area where water is collected and directed to the bucket but also check to determine whether the bucket is reinstalling correctly after it has been emptied.
Sep 02, 2014 | Dehumidifiers
Hi, I have a Haier HD306 Dehumidifier. I'm having an issue of the water dripping onto the floor. There is no crack or leak coming from the bucket itself. The leak seems to be coming from the back...
When my unit did that, I found that it was because the drain tube was plugged with lint and/or dirt...
Run a large tooth pick or wire up inside the drain and see if the water doesn't start running right out of there...
heatman101
Jul 26, 2011 | Haier HD306 Dehumidifier
My dehumidifier is only a couple months old and is leaking water all over the floor while collecting in the bucket too. Why and how can I fix it? - I will take it back under warranty but would rather just...
The leaking problem usually happens for 2 reasons,
1. If your unit is equipped with a float valve inside the top of the water collection bucket, it's stuck in
the UP position. Turn the unit OFF and unplug for the wall outlet. Remove and empty the bucket
if necessary. Look at the foam ball on the end of the float valve arm. If it's in the UP position
jiggle it, so that it returns to the DOWN Position. That should stop the wter from overflowing the
tank.
2. If the bucket is not installed properly into the bucket holder. Remove the bucket, empty the
bucket, if necessary and reinstall it. Be sure that the bucket fits "squarely" into the bucket
holder from top to bottom and that it does not tilt downward at the bottom.
It's also a good idea to check the pump switch for continual draining, to make sure it hasn't been accidentally turned ON.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 28, 2011 | DeLonghi DE500P Dehumidifier
I have the 25 pint unit and it leaks underneath the bucket. Water does get pulled into the bucket but when running water leaks out at the bottom and puddles on the floor. The bucket has been checked for...
If the unit is leaking under the bucket and you haven't been able to find a crack or hole in the bucket. The bucket may not be properly inserted in to the dehumidifier. Remove the bucket, empty it and reinsert it into the unit making sure that it fits in squarely (Top to Bottom).
If the above doesn't correct the problem, the drain tube to the bucket may be partially clogged. To check this, you will need an 18" long, plastic Zip Tie or something similar. But NO wire coat hangers. Turn the Master ON/OFF Switch to OFF and unplug the unit. Remove the bucket and you will see a drain hole or tube at the top of bucket cavity. Carefully insert the Zip Tie and continue to push it in unitl you reach the bend in the tubing. You will need to gingerly work it past this bend, until it either bottoms out or you run out of usable Zip Tie. Now, slowly remove the Zip Tie while rotating (twisting) it. As you reach the end of the Zip Tie be prepared for some water to follow.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 08, 2011 | Whirlpool 25-Pint Dehumidifier
The water seems to leak out the sides where the bucket goes in instead of the bucket filling up with water it goes on the floor.
sounds like the drain line might be clogged, with a piece of wire stick it in the line and see if it clears it. Hope this helped tim
Sep 25, 2010 | Haier AHD40 Dehumidifier
Water leaks from the bottom front under the bucket. Bucket does NOT leak. Attached a piece of tubing from the outlet to the bucket to no avail. still leaks. No visibe cracks anywhere.
Oct 07, 2009 | Haier AHD50 Dehumidifier
Water leaks around the bucket even the bucket is in place-bucket collects a little bit of water
It sounds like you need to check the drain under the cooling section. It can fill with dust, lint, cat hair, spiders, etc. and prevent water from draining into the bucket. First, unplug the unit. Don't do anything with AC power present. Then, remove the 2 screws under the front panel where the air filter slides up in and pull off the control panel. There are "snap" latches in the plastic near the top that can be (are) hard to undo, so be careful. You might want to have work gloves on because of sharp edges. Prying with a screw driver will cause permanent dents in the plastic. Also, there is a small, sleeved bunch of wires that goes up the left side to the operator buttons and display. Be careful not to damage it and the circuit board it goes to. Set the front panel aside, wire attached. There is no need to disassemble any of that. The drain is a small 3/8" hole in the black plastic floor of the cooling area at the front, right side. It seems to have a fitting for a hose that feeds through to the back of the unit. Clean any foreign material from it and everything else. Test it, with the bucket in place, by pouring some water in, if you want to. Then clean the dust off of everything so it looks new. Don't get the circuit board wet. Re-assemble, being careful with the front panel wire so it is not pinched and does not prevent easy removal/installation of the filter, and it should be OK.
Aug 17, 2008 | Comfort-Aire BHD-501 Dehumidifier
Leak
Mine did this last year. I took the housing off of the left side and found a clear plastic tube had popped off the fitting, I put it back on and it worked fine. The tube was toward the lower front of the unit.
Jun 01, 2008 | DeLonghi DE400 Dehumidifier
Haier AHD50 Dehumidifier Logo
56 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
