Question about Dell 3100cn Laser Printer
Printer is making 2" dark streeks down center of printouts
  • 105 Answers
Check your toner drum for scratches. If none, replace your fuser.
Posted on Oct 07, 2009
HOW TO INCREASE DARKNESS IN HP 4300
1. If you are printing using postscript driver, try using PCL6 - printout would be darker for grey scaled items.
2. Print in lower resolution 600dpi or 300dpi, printouts would be darker.
3. Try printing all characters as black
You can adjust darkness at the printer using the console menu.
In the Configuration Menu ' Print Quality sub Menu , there is a parameter called Tonor Density. Factory Default is 3. Set to 4 or 5 to increase darkness..
Sep 27, 2013 | Office Equipment & Supplies
Backlight
It is not the fault with its back-light I assumes. Might be of T'Con board. http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option. Make it sure.
Jun 24, 2013 | Sanyo DP46849 46 in. HDTV
When I scan or make copies the copy comes out very dark and streeked . i also had ink drip onto the feed paper
Might be that the cartridges are not seated well in the carrier or just needs cleaning. Remove the ink cartridges from the printer and follow the steps in this link http://bit.ly/bb33Ob on how to manually clean the print cartridge nozzles and contacts. Reload the cartridges and make some test prints again. If that's not going to resolve the problem, cartridges may be defective or got damaged and needs to be replaced. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Apr 22, 2010 | Lexmark X7170 All-In-One InkJet Printer
Visible "streek" down the length of my copy
usually this is caused by dirt or wite-out on the scanner glass. List the feeder and clen the scanner glass.
Nov 23, 2009 | Office Equipment & Supplies
Black color streeks. Cleaned 3 or 4 times to get
it seems youu already did all the troubleshooting.
Heres the thing you need to do:
-Try to reseat the printhead then calibrate printer., you can calibrate printer by pressing menu scroll down and look for calibrate printer.
-Please download your latest firmware at kodak.com/go/downloads
If the steps did not solve the problem it means that the nozzles of the printhead is defective you may call kodak for repair Toll Free 1 800 421 6699., GudlucK!
Nov 02, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How do i print in black and white?
When you do click Print, you get a option
Page Set up
Printer Options
CLick on Printer options and select B&W
You can also make choice of you want dark prints or medium.
Dark prints will waste lot of your toner.
Avoid thick black panels in your printout material
Oct 08, 2009 | Epson Stylus D88 InkJet Photo Printer
Dark printout
Have you tried a different toner cart? Common problem with reman carts. If that fails again, check the silver spring loaded contacts inside on the left and right that contacts the toner cart. Make sure they are not stuck inside the frame and that they are springy.
Aug 04, 2009 | HP LaserJet 5200tn Printer
No black when printing color
Dear Sir,
You are getting black lines in green color,and apperence of parallel light and dark lines because your colour catridge is almost empty.So solution is replace the catridge and take a printout. There is no proplem with a printer. i think it solves your problem.
good luck
chandrashekhar
Jul 29, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Striped line down right hand side of printout
all parts are ok just clean the printer it will work
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Dell 3100cn Laser Printer Logo
60 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
