Question about LG Flatron L1715S 17" LCD Monitor
I turn on my computer and monitor,the monitor display (Power Saving Mode) in a small box. Thanks Augusto/PT
  • LG Master
  • 5,568 Answers
The monitor is probably not receiving any video input; this is typical and you may have the same message with no computer attached.
Try reseating your video cable first but it could also be that your video card (or chipset if on board) has failed. The video input of the monitor is a rare point of failure.
Posted on Oct 07, 2009
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
Before Windows can boot-up the screen turns solid blue & a Dialog Box state "Entering Power Saving Mode". The screen then appears that the sleeping mode has occurred.
just switch off and switch on the monitor or press any button on keyboard to bring monitor from power saving mode thats all
Sep 23, 2010 | Dell E207WFP LCD Monitor
Every time i turn on my daewo monitor it saying "POWER SAVING MODE' then turn off power auto.
Hi this means your Monitor is in power saving mode , it is trying to save power when you dont use it, Change your power saving settings and it will work perfectly
Thanks
Dec 28, 2009 | Computers & Internet
THE COMPUTER IS IN A POWER SAVING MODE
I think you mean, your display is in power saving mode, this happens when there is no signal from the computer - the display then goes to powersaving mode, try restarting your computer, if it doesn't turn on the display. try the display on another computer to see if your display works.
if your display works with anohter computer, try it again on the problem machine, if its still in the power saving mode, then its not turning on, the computer is not turning on-
I would suggest to get a local friend or a tech to look into your computer and find the issue, if your handy with screwdrivers and know your way inside the computer, then you could take the case open and reseat the memory. try without any memory, then try with just one memory module. Then put them all back in, if this doesn't help, its not a memory related problem.
to save time i recommend you take the computer to a local professional.
Jul 15, 2009 | LG L1915S 19" LCD Monitor
Monitor cuts off
Hi...there,
In power saving mode to preventing futher damaged to the monitor. It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it... Happy Holidays!
Nov 11, 2008 | LG Flatron L1750S 17" LCD Monitor
Dell Ultrasharp 1800FP Power Saving Mode
go to control panel>power option>power scheme.
adjust the hard drive to 30 mins and everthing else 20 minutes.
also, go to display and adjust the screen saver to be longer. up to 9999min.
Jun 30, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Monitor stuck in "power saving mode"
just press the fn + F5 buttons and screen will appear
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
Analog Power Saving Mode
Right click on your desktop>Properties, then click on Screen saver tab, then at botton of the box you should see 'Monitor Power'. Click on 'Power' then Power schemes tab. Look at 'Turn off monitor' and set to 'Never'
Nov 30, 2006 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Digital power saving mode
Are you sure someone hasn't changed the power setting in windows. I've seen similar tricks pulled by so called mates. :-) If windows is OK then check the manual for the monitor and if you still can't crack it take it for a ride to the repair shop. It is under warranty after all. BMW
Jun 03, 2006 | LG 1720B 17" LCD Monitor
LG Flatron L1715S 17" LCD Monitor Logo
143 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
