Related Tags:
This problem should be removed because:
Problem with HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 incorrect print cartridges error message
I moved to the UK from the USA and brought my printer with me. In the USA I was using had printer cartridges black (94) and tri colour (97) and until today worked fine. The ink ran out so I replaced them both with black (338) and tri colour (343) and now get an error message "one or both print cartridges are not intended for use in this printer" although the packing states they are for this machine.
Any solution will be greatly appreciated
Solutions (3)
Best Solution
not quiet a solution dugguly but i've just had the same problem in reverse, i moved to the us with same printer, ink ran dry, it won't take hp94. after 3 phone calls and 4 emails with hp i learned that all hp printers sold after 2004 are regionalised, therefore a us printer will NOT WORK with UK bough cartridges and vice-a-versa. the only way round this is to call the HP support and ask to be taken through the step by step guide to reseting the region of your printer to the UK regional setting OR and this is my option, get friends/family in the US to ship US cartridges to you in the UK. Too bad as Tesco do a good line in gneric cartridges - Good luck - mattw
my cartidge is ok but my printer show cartidge error what i do in this condion
Some later machines can detect aftermarket cartridges and refuse to use them. I don't know why HP does not have the same type numbers available in the UK.
Cartridge is not intended for use in this printer
I have recently migrated from the UK to Australia and brought my HP Officejet 7210 All-in-One printer with me. It was fitted with a 339...
HP officejet 6210 all-in one
I bought a HP OFFICEJET 6210 in the UK about 14 months ago. I have recently bought genuine HP replacement ink cartridges Nos 338 & 334....
Our Australian HP PSC 1610 All-in-one uses no. 94
Our Australian HP PSC 1610 All-in-one uses no. 94 black ink. We have moved to the UK, where no. 94 cartridges are not available. We were...
My HP PSC 1610 all-in-one (problems included, pun
My HP PSC 1610 all-in-one (problems included, pun intended) was brought from Europe (b/w cartdridge 338) to latinamerica. My european...
Add Your Solution
The printer displays an out of paper message but...
the top sheet goes in twisted
printing text with lines through it
Hi, I have aligned and cleaned my black cartridge a few times and my printer still prints text with blank lines through...
Input voltage connector failure
Input connector mounted on PCB has contact failure. Without dismounting the printer, it is not possible to access. How I...
Fix-O-Meter
496
496 people viewed this problem
- 2 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top HP Printer Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
