Question about Microsoft Windows XP Home Edition
Closed a tab without saving changes
If i closed a tab without saving changes, is there any way to retrieve the document with the changes?
  • 379 Answers
Maybe. Reopen it and click "EDIT." If you are in luck, you can click "UNDO" Depends if you shut down the program or not. If you closed the program totally or shut down the PC, it most likely won't work.
Posted on Oct 10, 2009
I can't open my docs yet I KNOW they haven't been deleted because I am able to email them. How do I fix this?
MS Word offers several different views in which you can read and work on documents.
The view you are using when you save a document will be the default view when you open that same document the next time.
Likewise, if you open a document created by someone else, the view in which they saved it will be the default for that file unless you change it and save it again.
You can change your default Word template, though, so that new Word documents always open in the view of your choice.
Close any Microsoft Word documents or windows on your computer.
Locate the \"Normal.dot\" file on your computer.
This is the default template for all new Word documents. If you are using Windows XP, navigate to \"c:\\documents and settings\\username\\application data\\Microsoft\\templates\", changing \"username\" to your user name on the computer.
For Windows Vista or Windows 7, go to \"c:\\users\\username\\appdata\\roaming\\Microsoft\\templates\", again, changing the username to your user name on Windows.
Right-click \"Normal.dot\" and select \"Open.\"
A new Word document will open, which is actually the default document template.
Change the view to the one you desire.
To do so in Word 2003, go to the \"View\" menu and click on the view you want to use.
In Word 2007 or 2010, go to the \"View\" tab and select a view.
Type something into the document and then delete it.
This allows Word to recognize that a change has been made to the template without adding any unwanted items.
Click the \"Save\" button or press the \"Ctrl\" and \"S\" keys to save the changes to your default Word template.
http://word.mvps.org/FAQs/General/SaveViewAndZoom.htm
Aug 29, 2013 | Microsoft Word 2010
I can't find my auto saved document
Step 1:
What sort of document IE: word , excell , office ......
Microsoft Word's AutoRecover feature periodically saves your document while you're working in it, even if you forget to save it manually. If you close the document accidentally, Word closes improperly or you unthinkingly write over a document or change something important, this function can save you from losing all your work. Although Word doesn't AutoSave constantly, it might have automatically saved your lost document more recently than you manually saved it. Word 2010 makes this rescue process even easier than earlier versions of Word; it stores all recently AutoSaved versions of your documents under the "File" tab.
Open the document for which you lost information. For example, perhaps you were working in a document that you had previously saved, but then Word closed and you lost your most recent work. Click the "File" tab. Click on the most recently AutoSaved version of the document under the Versions heading, next to the "Manage Versions" icon. An Untitled, Unsaved Document b> Open Microsoft Word. Even if you never saved the document, and you can't find the file on your computer because you never gave it a name, Word might have saved a version of it. Click the "File" tab. Click "Recent" on the left column of the File screen. Click the "Manage Versions" icon at the bottom of the middle column. On the drop-down menu, click "Recover Unsaved Documents." Word presents an Open dialog box, taking you directly to the Unsaved Files folder that Word automatically created. Click on the document that you want to open, then click "Open" at the bottom of the dialog box. Click the "Save As" button on the yellow bar that appears above the document, below the Ribbon; in the pop-up menu, give your document a name, choose its storage location on your computer and click "Save."
http://office.microsoft.com/en-us/word-help/automatically-save-and-recover-office-files-HP010354296.aspx?CTT=1
Mar 10, 2013 | Microsoft Office Professional 2007 Full...
My GPS says " no detailed maps found that support routing. The Nuvi cannot be used without them." Tried resetting and no change
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your garmin device. Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Creating an unlock code file for Mac:
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
If you have a second maps you may also need to unlock it e.g. if the first map is USA and second is EUROPE this may also need to be unlocked
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Sep 25, 2010 | Garmin nuvi 205W GPS Receiver
After i updated my nuvi 255w now it is saying '' no detailed maps found that support routing'' the nuvi cannot be used without them.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Sep 20, 2010 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 205 will not bring up maps... it is saying, 'no detailed maps found that supprt routing. the nuvi cannot be used without them..' and i cannot use it.. what do i do?
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Sep 01, 2010 | Garmin GPS
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
*nuvi x70 owners with transatlantic mapping will need to follow the Creating an unlock code file instructions above for their U.S. mapping and then create another unlock file for their European maps:
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 10, 2010 | Garmin nuvi 205W GPS Receiver
To retrieve deleted content in word document
if your word document is still open , yes you can retrieve your deleted pages if not you don't have chance .
if it still open , undo button can do that.
Sep 12, 2009 | Computers & Internet
Icrosoft word tracking mode I received a document with changes in tracking mode I accepted all changes and saved. Now I cannot turn off tracking mode. What to do?
Turn off change tracking When you turn off change tracking, you can revise the document without marking what has changed. Turning off the Track Changes feature does not remove any changes that have already been tracked.
Important To remove tracked changes, use the Accept and Reject commands on the Review tab in the Changes group.
  • On the Review tab, in the Tracking group, click the Track Changes image. default.aspx?assetid=za102097011033
May 26, 2009 | Microsoft Office Communications 2007...
Missing shortcuts in MS Word 2003
Open WORD
Go to TOOLS
Select OPTIONS
In VIEW tab check 'Startup Task Pane'
Close WORD to save changes
Open WORD and Task Pane should be back!
Feb 26, 2009 | Microsoft Office Word 2003 for PC
Microsoft Windows XP Home Edition Logo
27 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
