Lost all channels
Have just done a power scan on my eurovox box and have now lost all channels how do I get them back?
Same thing happended to me, but after hitting the red button ( when in Menu->Installation->Fast Install) - 'Update Channels', after about a minute it updated all the channels again.
Posted on Oct 10, 2009
Can any tell me how to setup a eurovox its the 2007 version ive scanned the channels theyve all came up but skysports, movies and all the other channels you pay for wnt come on. i used to have a starview...
Dont know if it helps or not but this is the method i used to set up the eurovox max when i first got it - it may work for you.
EUROVOX MAX SETUP
This is the method I use for setting up the eurovox max box but I have been told that it works for versions 1 and 2 as well
PLEASE NOTE : IF YOU ARE USING A SPLITTER IN YOUR SETUP THIS MUST B E REMOVED for the initial POWERSCAN as the box needs to scan from a pure signal- this will ensure all channels being found. – scanning throught a splitter can result in the loss of 50+ channels.
Firstly before you start to scan the box you need to:-
PRESS MENU
GO TO CONFIG
GO TO CLEAR DATA – IF IT ASKSYOU FOR THE PIN PRESS 0000
SELECT – ERASE ALL CHANNELS
Then it will ask you are you sure so press OK
Then wait a few seconds then press EXIT and EXIT again
What you need to do now is a POWERSCAN.
The following is a step by sep method of carrying it out!
Press the MENU button
Go to INSTALLATION and arrow right to USER INSTALLATION
Type in your pin (normally 0000)
Press the YELLOW button for POWERSCAN and change the mode to FULL from Normal by arrowing right to reveal FULL
Now press OK, this will begin the BRUTEFORCE POWERSCAN which can take up to 40 minutes,but it is guaranteed to find every single channel on the network in your area.
Once done the box will switch to a random channel to indicate it has finished !
You will now have around 240 or more channels (in some cases regions can receive up to 330 channels!)
You now need to switch to a non free channel and let the box update the codes – this could take a minute or two, it will indicate on the screen “updating please wait” once finished all channels will now be unlocked.
That’s it you’re all done … HOWEVER …. If you find that you get no channels at all there is a further adjustment you can make to ensure you get the 250 plus channels that your area box will be able to receive and again it’s quite simple to do!
First press MENU
Then go to USER INSTALLATION
Type in your pin (0000)
Press YELLOW button to POWERSCAN
Then change the mode to NORMAL
Then arrow down to the SYMBOL RATE and if its on 6.952 then change it to 6.887 (or vice versa!!)
Then press OK and it will carry out a scan like the powerscan of before.
If after you have tried this and you still are channels short then keep the symbol rate at the new figure but adjust the scan to FULL and try again.
Sep 16, 2009 | StarTech.com StarView SV211K 2-port KVM...
I have a eurovox, i recently lost sky sports 2 and 3 in Ireland
First call and make sure they are not having technical difficulties on their end. That could be the issue.
Sep 15, 2009 | Televison & Video
Hi.i have lost sky sports and setanta sports
Just updated using below, have got all back
have u tried a factory reset 0000 to delete,power off at back/on and autoscan ur provider,and emu to on,usually brings them back,do not scan thru splitters as u will lose channels.
Jun 10, 2009 | StarTech.com StarView SV211K 2-port KVM...
Lost certain channels on Eurovox
run auto scan......please make sure you dont run power scan.....once scan is done you should get all the missing channels back.
Jun 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
Did power scan by mistake and now no channels
restore to factory defaults and than delete all the data ( all the channels ) once done . run power scan and your box should be up and running again..... :)
Lost setanta channels glasgow 54 01
put codes in and do scan again it should bring channels back they willl be at the bottom of the channel list
Dec 07, 2008 | StarTech.com StarView SV211K 2-port KVM...
Eurovox problems
update your firmware theres a new fix on the bigmaq site easy
Dec 03, 2008 | StarTech.com StarView SV211K 2-port KVM...
I have eurovox max 2008
due to upgrade in the software of the eurovox and other recievers you will need to upgrade your box once you have done that power scan your box and it should be up and running.
Dec 01, 2008 | Audio Players & Recorders
Eurovox problems
try using these if you have telewest updated 29/11/08 3.00pm
5A 01
98 B0 BA 52 D3 21 08 B4
D2 EA 29 B7 B5 52 E9 AD
Aug 06, 2008 | StarTech.com StarView SV211K 2-port KVM...
142 people viewed this question
 Grubhead
Grubhead
