Question about Canon PowerShot A630 Digital Camera
FLASH IS NOT WORKING PPROPERLY
FLASH IS NOT WORKING PROPERLY . THE PICTURES ARE 2 SHADES DARKER.
Darker screen after replacing a samsung dlp lamp
DID YOU USE THE FOLLOWING LAMP
BP96-00826A (PHILIPS WRITTEN ON THE LAMP)? ALSO PLEASE CHECK THAT THE LAMP IS COMPLETELY SEATED OR IT WILL RESULT IN BRIGHTNESS ISSUES. THERE WAS ONE THAT I REPLACED THE LAMP IN AND I NOTICED THAT THE DIAL OPENING ON THE LAMP HOUSING WAS A BIT SMALL AND WOULD NOT ALLOW THE COMPLETE SEATING OF THE LAMP AND I HAD A DARK PICTURE AS A RESULT. I USED MY CORDLESS DRILL WITH THE PHILIPS HEAD STILL ATTACHED AND REAMED THE HOLE LARGER AND IT SOLVED THE PROBLEM.
HOPE THIS HELPS.
Jul 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
19" aoc lcd monitor flashes pink constantly and turns black
THIS COMPUTER THAT I AM ON ALSO DOES THE SAME THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRR...................=.="""""
Apr 17, 2009 | AOC 917Sw 19" LCD Monitor
Images are coming out REALLY dark
first GET TO AUTO MODE WITH FULL AUTO
if this doesn't work try going to manual and setting the exposure up to +1 or +2
Feb 04, 2009 | Nikon D40x Digital Camera
Uneven flash
Look carefully at your images taken with flash... on the horizontal image is the lower part of the image slighty darker and have a rounded fall off at the edges? Is the vertical image dark side a straight hard line or is there a rounding to the top and bottom?
What we are looking at is if you have a very wide angle lens with the lens shade attached to the lens, then the built-in flash catches part of the lens shade and make a shadow on your subject... take the lens shade off and try the same shot and see if that makes a difference...
Have a great day...
Ed
Apr 03, 2008 | Nikon D40X Digital SLR Camera Digital...
White pictures, low battery life, few pictures
I glued a small peice of plastic under the flash and above the camera lens to shade it from the flash when it goes off. I then only had 2 pictures out of 40 that showed a white picture. The plastic peice only sticks out about 1 inch and didn't affect the flash on the subject. I also drilled holes in the bottom and hooked up a 6 volt tractor battery to it this gave me over 1 month of battery life with another identical camera
Jan 21, 2008 | Moultrie MFH-DGS-200 Digital Camera
Pictures are underexposed
When you are photographing scenes with mostly light objects (for example, snow, water, and sand), the picture is usually underexposed (darker than it really is). The camera meter registers the brightness of the scene and tries to set the camera lens and aperture for an exposure based on average brightness levels (18% reflectance) causing it to underexpose, as in the following picture. When you are photographing scenes with mostly dark objects (for example, shade, shadow, and overcast skies), and very few light objects, the camera may overexpose the image, causing it to be too light. If you have a flash on your camera, you can compensate by adding "fill flash" for some extra light. If your camera has an exposure compensation adjustment, you can increase or decrease the exposure to correct for these exposure problems. Increase the number to make the image lighter, and decrease the number to make the image darker. You may want to try a series of shots with different exposure compensation adjustments to get a feel for how much difference these adjustments make.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Canon PowerShot A630 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
