Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC 24 is clogged, not suctioning. How can I check the tubes for a clog?
    Problem Solver:
  • 9 Answers
I removed the flexible tube sections and blew compressed air in reverse flow path to remove the clog. however I have noticed my vacuum getting clogged more often and would like to know how to clean the insides of all the pipes to remove residue alloing buildup
Posted on Jul 08, 2010
No suction from dyson dc24
Clean or replace filters if needed. Check for suction at wand, if not good could be a clog somewhere or clogged filters, or a leak in the suction somewhere. If good at hose but not at floor it could be a clog or malfunction in changeover valve area. Make sure brush roll is spinning good and brush roll not worn out or frayed.
Mar 14, 2017 | Dyson Vacuums
I have a dyson animal d17 i have taken apart completly and cleaned all filters and clogs and i still have little to no suction and wont turn on in the upright position
With no suction you should check the venturis. They can become clogged if you suck up wet dust, wet cat litter, etc. You\'ll need a Torx Screwdriver to get it apart. See where that gets you.
Jan 07, 2014 | Dyson DC14 All Floors Upright Vacuum...
My dyson vacuum motor is sounding very high pitched... The tubes are all clear and there is suction with the tubes not not real good suction on the beater brush area....
Your dirt path is clogged, probably not far from the brush area. This is the reason you noticed the hi-pitch sound coming from the motor.
You may have to remove the hose to clear it.
Jan 19, 2010 | Vacuums
I have a dyson dc 17 what is the best way to thourghly cleaning , so I can get better suction , also do you have a instruction manul to. I seem to have misplaced mine thanks
The first step towards improving the suction is to clean the circular HEPA filter. The filter also houses a circular sponge which should be rinsed and dried before putting it back. Check the HEPA filter to see if it needs replacement -- will look muddy! Another quick check is to remove the HEPA filter, run the vacuum cleaner momentarily in upright position to check if suction is restored at the hose end.
After doing this if suction is still poor or non existent, you should detach the transparent canister - a bit tricky since the release rod for the flap has to be aligned when you want to reassemble the unit.
Once the canister is removed, you should check and clean the center tube/shaft for any clogged dust (use a wire coat hanger if needed to pry out the dust). This tube gets clogged if the vacuum cleaner was used to pick up damp/wet spills etc.
Sep 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction - Dyson vacuum
Hi If the Dyson is throwing out dirt at the back, it could be three possibilities:
1) The main floor head suction channel is blocked. Check the sole plate where the beater bar is, or if you have a cylinder/pull along model check the floor heads and main extension pipes.
2) Check all the inspection tubes especially the bottom part where the main handle hose is. Also check the filters are clean as well as the Cyclone shroud honeycombs are completely unclogged. Use of the upholstery brush is ideal for dust removal on the cyclones.
3) Check the main inspection areas on the Dyson as sometimes a back log of clogged dirt can get stuck. Also check the dust channel points when then bin is taken out.
Hope all this helps!
Jun 19, 2009 | Dyson Vacuums
Hose is not getting any suction
when vacuums shut off randomly it usually means they are overheating. this can be caused by a clog somewhere in the line of suction, or, perhaps due to a very dirty filter - either way, the motor is working hard and getting too hot.
try removing all the various tubes and parts along the suction route and checking for clogs (a flashlight might help too). also, have you rinsed out your two pre-filters lately as recommended in the Dyson manual? it might help.
Apr 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Apr 11, 2009 | Dyson DC14 All floors Bagless Upright...
Dyson DC17 Animal Vacuum
you just need to blow those holes out with a air compressor or similiar device and the filter can be washed in water and dried for 24 hours every once in a while, this is just how the vacuum works, nothing is perfect
Mar 02, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
874 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
