Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave wont come on at all.
Ge spacemaker 2.0 JVM2070. Green display panel froze, I shut unplugged it. When I plugged back in I got nothing. Panel does not light up and microwave fan, light, or vent does not come on when button pushed. What can this be?
  • Anonymous Dec 26, 2007
    I heated the food for 4 minutes, stirred and then went to heat it again and the power doesn't work. No lights, fan, power, nothing!
Replace the fuse. You have to remove the top grill and then you will find it above the display
Posted on Dec 29, 2007
My GE Spacemaker microwave - control buttons seem confused. When I press one of the buttons, either nothing happens or it goes to the wrong screen. What is up?
On the JVM2070- and PVM2070-series microwaves, GE does not make service information or separate parts available.
So when you have an error with the controller that does not involve the smart board (and this error does not) then you have to order the control panel subassembly, which on your model (PVM2070SM1SS) is part number WB07X11143 and you can get it from the Pros here for $477.83 (subject to change).
It's very expensive but it's actually simple to replace that part yourself.
You would remove the control panel assembly as shown in our video here, then remove your smart board and attach it to the new control panel subassembly.
Some connectors on the relays have a lock:
If it's under warranty or GE Customer Service would give you a break on the the part cost, that would be a big plus for you.
Aug 22, 2012 | Microwave Ovens
How do I unlock the touchpad of my Profile 2.0 Spacemaker Microwave Oven # JVM2070
calvin,
If you have access to where your microwave is plugged in, unplug it for a few minutes and then plug it back in. This will reset your contol panel. Then follow your book directions to reset the time on the clock. Hope this helps!
Nov 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Hello, I have a GE Spacemaker 2.0 (JVM2070SK) and with an electronic touch panel. The unit is 3 years old, the panel lights up with all the options however, when you touch the screen nothing happens. Then...
This is a common problem, and they're often intermittent.
You'll need a new touch screen.
You can get complete details on all these 2070-series microwaves on my page here:
http://www.microwavecontrol.com/jvm2070.htm
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 01, 2017 | GE Profile Spacemaker Over-the-Range...
I need to replace the control panel on a GE spacemaker 2.0 microwave. Model is JVM2070SK01. How do I remove the power vent to gain access to the control panel?
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at
http://www.microwavedisplay.com and swing it down, but without disconnecting the wires.
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward.
On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
They're our favorite supplier.
Aug 22, 2010 | GE JVM2070 Microwave Oven
Panel periodically acting up - says there is a short in the panel
Hello there:
what this is trying to tell you is that your control panel is starting to go out due to a failure in the controle assembly
yes it is feasable to replacethe panel youwill just have to contact the manufacture of the microwave and get a replacement panel/ controle board ok
I hope that this is very helpful for you
Best regards Michael
Nov 21, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE jvm2070 microwave touch panel does not work, but the fan and under light still works?
The only thing you can do is re set the main board, unplug the unit fot a minimum of 1 hour then try it again, if not you main board is out (this is caused by replacing the light bulbs with out unplugging the micro most of the time) If it is not in warranty I would advise to replace rether than repair, you get an average of 7 years out of them these days. Good luck
Jul 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do I open the front panel of GE Spacemaker 2.0 ? Fuse?
there are screws either on top of or in the grille that allow you to remove it. after screws are removed, open the door, pull lightly toward you starting at the control side if it does not pull, then it may have to be pushed toward the hinge side, then pulled out. behind the grille, is the screw attaching the control panel. lift the panel up before pulling out. Just to add a thought,if the display lights up it is probably not the fuse, although, in some models there is a high voltage fuse, it is pretty rare.
Jun 16, 2009 | GE Profile Spacemaker Over-the-Range...
GE Spacemaker JVM1640SJ Microwave Oven Logo
529 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
