Question about GE GSH25JFR Side by Side Refrigerator
Water button not work
My GE water button still lights on but water doesnot come out as pressed. cube ice still work as usual;
My GE re was bought 2 years ago
Please help
  • vinnef Jan 07, 2008
    You may have a freeze in the line inside the dr. The fastest way to pin point this is to take the line loose behind the grill at the front under the dr. Water only travels through this line when you push the dispender arm for water. You push the ring in towards the connecter and pull the line out at the same time. It will slide out real easy if you do it right. If you are pulling with any force to disconnect something is not right. To connect simply push line back into fitting til it stops the pull out slightly to to ensure it is set. With the line appart hold it to where it can dispense into something to catch the water and activate the switch. If you have water to this point which is were it will enter the dr next you will have eliminated all other possible problems except ice in the dr. There are acouple of articals on this sit e on how to fix that with that simular model no. Also check to see if that problem may be covered under GE recalls for that paticular problem.
    Problem Solver:
  • 7 Answers
You can check the site again on how I fixed the same problem. GE also has a recall on many refg. with this same problem. Probly a frozen line inside dr.Quickest way to isolate is to disconnect line at were it enters bottom of dr. and press dispenser tab. If you have water to this point it is about 99% sure a freeze in dr. No water means probly selenoid or the switch or something else. Ice and water line do not feed off same line , ice will dispense even if water does not.
Posted on Jan 07, 2008
PSS23MSTC GE PROFILE WATER WORKS, ICE CRUSHED ICE INDICATOR LIGHT DIMS NO ICE IDEAS?
clean built up ice in the door where ice comes out.....make sure the metal bar is down. its located inside the tray where the stored ice is.
Nov 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE refer will not dispense cubed ice
I have the same problem. My GE refridgerator won't dispense ice cubes.
May 01, 2009 | General Electric GSS22JET Side by Side...
I have a GE Frig 2 years old It make crushed ice when you press the cubed button. It's making cubed ice fine just not dispencing everything else works fine. It is model No. GSH25JSTASS and Serial NO....
could be a problem with micro switches inside the dispenser. it has small switches that when you press the button outside, you are pressing a switch inside and if they are cross wired or what ever, these things happens. if you are familiar with electrical wiring trouble shooting, then i could guide you but if not, then i suggest you call a qualified tech to help you with this kind of problem.
it is as if the wires were interchange. cube button would dispense crushed ice then the crushed ice button is not working.
tnx 4 using fixya,
drcool
Oct 07, 2008 | GE Refrigerators
GE Freezer Side Ice Dispenser
It isn't supposed to free wheel and the only solution that I know of is tumbler replacement. I have the same issue and am currently hunting replacement parts.
Jun 16, 2008 | Refrigerators
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker does not dispense cubes
THE SOLENOID IN THE ON THE ICE MAKER MOTOR IS NOT WORKING IT HAS ICE BUILD UP ON IT OR IT HAS A SHORT IT PULLS THE PLUNGER THAT OPENS THE FLAP THAT LET ICE CUBES FALL OUT. REMOVE ICE MAKER AND THER ARE 2 5/16 SCREWS THAT HOLD PANEL IN THEN UN PLUG MOTOR AND USE HAIR DRYER & DEFROST MOTOR AND SOLENOID SHOULD WORK IF NOT MAY NEED TO REPLACE SOLENOID.
Dec 22, 2007 | GE GSS20IEP Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
144 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
