What parts need to be replace,, is it worth replacing ??
This tv uses two power supplies. Do you hear a high pitch squeal? If so replace the small G power supply. If not make sure fans turn freely and finally change the large power G board. Look for obvious hot spots and swollen caps before buying board as the small bd. is approximately 129.00 and the large even higher. Part numbers on stamp on each board.
Hope this helps: Sam Farrell
