Question about Refrigerators
Some fan making a loud noise. When open either
Some fan making a loud noise. When open either of the doors, sound disappears. Once door closed again, noise starts up again. Display reading ER FF. What does this mean?
  • 308 Answers
It sounds like it is probably your evaporator fan, seeing as that fan will cycle off when the door is open, and resume when you close the door. Either some how something got in to it, or it is going bad. Hope this helps
Posted on Oct 07, 2009
Freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
Jun 17, 2009 | Samsung RS2630WW Side by Side Refrigerator
Making a loud noise
yes. is the fan hitting ice. the fan activates when close the door the upper baskett press the fan and light switch............... good luck.......... LEAVE YOU COMENT IF IT WAS GOOD FOR YOU
May 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Loud Noise when freezer door is closed (as if fan is not working)
it is the fan or the blade hitting something when you open the door it shuts the fan off and on when closed you need to gain access to the fan and see if it is the motor of the blade before you lose any food
Jan 08, 2009 | Maytag MFD2560HES Bottom Freezer French...
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Refrigerators Logo
332 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
