Question about Dryers
I have the Kitchen Aid electric dryer - KEYE760WWHO. The timer was not allowing the dryer to shut off automatically. I am under contract with PSNC gas company here in North Carolina. Their technician replaced the timer with a new one. The only cycle that works correctly is permanent press. Thhe knob is off about 1/4 of an inch. The timer has been replaced two times. The tech says it is the wrong part. Whirlpool, the new owner says it is correct. The tech says he needs a timer that lets him get from BK to BU. I don't know what to do! Does anyone know anything about this?
  • 5 more comments
  • nancyrosen Oct 07, 2009
    This replacement part is the same part that has always been provided for this machine. Whirlpool/Kitchen Aid insists that it should work the same as the original part. I asked if there new anymore information available and I was told that in 2003 it was noted that the part was in the wrong bin but that the problem was fixed. The latest timer installed into my machine (this week) has a production date on it of 2007 so I do not think that is the problem. The service I have is not a Whirlpool certified tech and therefore they will not speak with him.
    Are you saying that I should threaten Whirlpool about making this right? I just want to be sure about this. This machine was produced in 1991 and the company has changed ownership.
    The local gas company contracts monthly to keep many appliances in your house running with certain stipulations. For $12 a month it covers the refrigerator with ice maker, dishwasher, washing machine, dryer, and fireplace gas logs. They cover a lot and would be more than wiling to cover this timer that costs $92 and the extensive labor. They already paid one tech in June for the parts and labor. The part is Kitchen Aid 3389865. I asked Kitchen Aid /Whirlpool what to do? Perhaps the part was still in the "wrong bin" - the trouble in 2003. She said I need to buy the part from them and if it does not work they will look into it. They will not put an inquiry in unless I but the now 4th unit form them! This is ridiculous.
    PSNC the gas company who runs my contract will pay something toward a new dryer, but that is not what I want. I want to use this one until it dies.
  • nancyrosen Oct 08, 2009
    Please comment on the information given previously. Thank you.
    The timer is installed. I will pass this on to the tech and get back to you. Thank you.
    I can tell you without speaking with the tech that it does look like it. The one I have has part # 3389865 on it from the same company. The technician said that they all look alike and only differ in the inside. What are you thinking? The tech is saying that he need a connection from BK to BU.
    Please review and comment. Thank you!
  • 6,784 Answers
HI. Ok, the timer mechanism that you have ordered should indeed have the BK and BU connection pins. I have illustrated this below. As you can see, the RED lines are distinguishing the connections(BU,BK,W-BU). They do exist on your timer. If your timer dose not look like the one in the picture below, you have purchased the wrong device. Click here to purchase the correct timer, if this is the case.
With that said; Due to the symptoms you are experiencing, this leads me to believe that the electronic cycle control board has failed. This will be the culprit. This board is located inside the control panel. This board controls all the cycle action and can disrupt the timer functions if it is damaged. Click here to purchase your new electroninc cycle control board.
Posted on Aug 09, 2010
  • Michael Masters
    Michael Masters Aug 09, 2010
    • Additionally; I would advise to instruct the tech to inspect the moisture sensors located at the back of the drum. These electrodes(2) are connected to the electronic cycle control board. These sensor bars may be covered with lint. Have them cleaned or replaced.
  • Dryers Master
  • 3,361 Answers
First,examine the timer. The correct part number is 3389865. The number is printed on the timer. Second,remove the knob and re-orient the knob on the shaft. There should be a flat side on the shaft and a corresponding flat side inside the knob. Make sure they mate correctly. Before you remove the timer,note where the timer pointer is pointing. When you replace the knob see if there is a significant difference in the pointer. Check the inside of the timer knob,it may be cracked and stripped causing it to be on the wrong cycle when it is turned. The failure to cycle and stop in the AUTO cycle is probably related to a bad moisture sensor for the auto dry cycle. Make sure the interior and exterior vents are clear of any blockage. A blocked vent will cause the dryer to continue running.
Posted on Oct 08, 2009
    President:
  • 1,714 Answers
The part number and the timer is here, does this look like your timer?
Part 548369
  • 11,896 Answers
Either the timer switch, selector knob, or door switch is faulty or has bad connections. You can check with an ohmmeter and or a voltmeter
    President:
  • 1,865 Answers
No, but notify the responsible party that they have 7 days to correct the problem, or you will file a small claims action to recover the cost of the dryer, and purchase a new one
Posted on Oct 07, 2009
  • buffalonyman
    buffalonyman Oct 07, 2009
    I'm not sure what "under contract" means. If Whirlpool has an obligation to maintain the machine in good working order, then I would enforce that obligation, that's what I meant by pursuing a small claims action.
    I couldn't locate a timer for your unit, so I don't know what the problem could be.
    Brigadier General:
  • Dryers Master
  • 3,614 Answers
Difinitely it can be the part was not compatible on your unit, it will operate but it will not fuinction as it use to be, some connection could not be attached.
Buzzing noise from my dyer
You may be experiencing some feedback through a buzzer from the timer. Below is a link that may be of some help.
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
Oct 23, 2017 | KitchenAid KEHS01P Electric Dryer
Kitchen-Aid Electric control panel buttons stopped working
This may sound facetious, so don't get offended.
Did you set your clock to the correct time?
Did you clear any and all preset timers?
If none of that helps you can usually find roaches in the strangest places. If you have no roaches, then moisture and heat are the likely culprits which means that your blister pads are simply worn out. Unfortunately these are coated with graphite and don't last forever, so a timer replacement would be your only option unless your touchpad is separate from your timer.
Mar 05, 2010 | KitchenAid KERC507 Electric Kitchen Range
I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Jan 02, 2010 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Aid Electric Dryer Model # KEYE678BALO, won't start.
This is most often caused by a bad thermal fuse or thermostat high limit cutout. Check them for continuity (with the machine unplugged, of course) They should have continuity -- replace them if open. They should be available at www.appliancepartspros.com Also, if one or both are bad, check the dryer vent as they often are damaged by high heat due to a restricted vent pipe. The website above also has diagrams to help find the parts on the machine.
Dec 30, 2009 | Washing Machines
Kitchen Aid electric dyer, will not start. I have power to the dryer and the timer runs, but the drum will not turn after pressing the start button. If the door is opened after setting the timer, there...
You have a bad thermal fuse , located on the blower box . A small white plastic piece with 2 wires going to it . May have to remove the front panel to access it . Usually caused by kinked vent hose or clogged vent .
Jul 31, 2009 | Dryers
Dryer wont start
I would check the door swith first.
Jul 15, 2008 | Estate TEDX640JQ Electric Dryer
Roper dryer won't shut off
The timer motor isn't moving the timer. You'll need to replace the timer. Turning the timer **** to off should stop the machine.
Exception: If the shutting the door automatically starts the motor, then the start switch/relay is probably shorted.
Mar 10, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
156 people viewed this question
Top Dryers Experts
