Question about Dewalt DC011 AM/FM Radio
Dewalt Radio won't hold presets or clock time
When i turn the radio off, without unplugging or removing the battery, the preset station memory and clock reset. Any ideas?
Replace the two AA batteries in the battery compartment.
Posted on Nov 30, 2009
  • 60 Answers
Are contacts clean where the battery connects to? scrape with sand paper or sharp object. Check to see if the plug has not come away from LCD circuit board inside.
Posted on Nov 28, 2009
How do I delete preset stations? I can add a new preset, but I have to go through all the presets to get to the station I want. I would like to delete a number of them.
The backup battery needs to be removed from the clock radio. Then, unplug the device from the wall and count to 15. Plug the radio back in and see if the presets have been purged. Unplug the radio again for safety, reinstall the backup battery, plug the radio back into the wall and begin reprogramming.
Now, if you really don't want to have to reprogram all your stations, I suggest you look at the company's website for a free download of the user manual which will give you step-by-step instructions on reprogramming the radio.
Feb 03, 2016 | Audio Players & Recorders
KD-R805 does not store clock settings
first of all you must be able to check out a few things like do you know how to set your clock for the kd-r805. if you can check to see if you set your clock and set your presets for radio station to be saved. set your clock and set all your station presets once done. Once you have done that turn off the car wait about 60 seconds then turn your car back on to power up the radio and see what happens to your clock and presets . if your clock and presets are not still saved this means that who ever did the radio install has the yellow memory wire connected to switch ignition and not constant battery wire from the factory harness. have someone fix it. If the clock and station presets are still save then it was that you don't know how to program the clock.. how to program your model radios clock .......
STEP 1 : TURN ON POWER TO RADIO
STEP 2 : PRESS AND HOLD MENU UNTIL THE MAIN MENU IS SHOW ON RADIO SCREEN PRESS AND TURN THE VOLUME KNOB TO MOVE THROUGH THE MENU ( YOU MUST CANCEL THE DEMO FIRST TO BE ABLE TO PROGRAM THE CLOCK).
STEP 3: TO SET THE CLOCK SELECT THE CLOCK IN THE MAIN MENU SETTING ROTATE THE VOLUME KNOB AND PRESS IT ONCE TO SELECT THE CLOCK SETTING.
STEP 4: ADJUST THE HOURS AND THEN PRESS THE VOLUME KNOB TO MOVE ON TO THE SECONDS .
STEP 5 : THEN SELECT 12HR OR 24HR TO BE DISPLAYED
STEP 6 : RETURN TO THE PREVIOUS MENU BY HITTING (BACK BUTTON)
STEP :7 TO EXIT SETUP OR MENU HIT THE (MENU BUTTON)
radiorepair@www.windowtintingin239.com
Oct 26, 2013 | Car Audio & Video
Can't set the radio stations
When you find a frequency that you
want to store in memory, press one of pre-
set tuning buttons 1through 6 and hold until the
preset number stops flashing.
The number you have pressed will flash in the
preset number indicator and then remain lit.
The selected radio station frequency has been
stored in memory.
The next time you press the same preset tun-
ing button the radio station frequency is re-
called from memory.
May 29, 2010 | Pioneer DEH-2800MP CD Player
How do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Jan 01, 2010 | Sony CFD-F10 Radio/Cassette/CD Boombox
Clock is in military time mode. How do I reset to regular? Also I want to preset radio stations and I've lost my manual.
Here is your manual in PDF format:
http://www.bose.co.uk/GB/en/images/Wave%20Radio%20CD_tcm6-4104.pdf
To set AM/PM (12 hour) or Military (24 hour) time - With the system off, hold down Alarm Setup and press On/Off to switch between AM/PM (12 hour) and Military (24 hour) time formats.
To preset up to 6 AM and 6 FM stations - Use the Track/Tune buttons to find the desired station. Then, on the control panel only, hold down any Preset button until the preset number lights. The station is now preset to that number.
Dec 05, 2009 | Bose Wave Radio
When I shut the radio off the clock and radio memory goes to How do I set the clock and stations so that when I tur it on I have the clock and stations.
Have you inserted 2 x AA batteries in the back where you charge the Dewalt batteries? there is a cover with a black phillips screw, this is where the AA batteries go for the memory clock & radio presets.
Nov 28, 2009 | Dewalt DC011 AM/FM Radio
How do I set the clock and preset radio stations on a Pioneer fhp800bt Premier?
Usually, you need to have key on and radio off. press and hold function button till u see settings menu. Set radio stations by press and hold preset # while on station till beep or display blinks.
May 07, 2009 | Car Audio & Video
2003 Nissan 350Z radio only has 1 radio station
manually tune in new stations and hold the preset button until it's in the memory
Mar 15, 2009 | 2003 Nissan 350Z
I can't preset radio stations
this is how i preset my stations, im not sure if you have done this before.
fm can save 20 stations and am can save 12
1] chose your desired station
2] press & hold the play/memory button until P01 pops up and flashes
3] to save the station, press & hold the play/memory button
if you'd like to save another station, then repeat steps 1 & 2,
then press the play/memory button again until P02 pops up,
repeat step 3.
to listen to your preset station, all you have to do is press the play/memory button.
hope this helps
Mar 12, 2009 | Starlite Next Play Clock Radio with iPod...
Need an owners manual
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
Apr 05, 2008 | GPX HDT4004SP AM/FM Radio
Dewalt DC011 AM/FM Radio Logo
2,635 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
