Question about Samsung Spinpoint MP0402H 40 GB Hard Drive
Samsung harddisk problem
I have problem to creat partition, when i run fdisk command,
first time it go 79% then 100% once again 100%,
what i do for?
How to Find Bad sectors and how to block bad sectors manually?
Posted on Dec 24, 2007
I cant install windows 98 se in a computer compaq 900 series because i lost its installs disk they were 2 and i install from another cd all is great but when it restart goes black with a mesage "...
Hello Pushan, can you send detailed specs of your system, meanwhile try the following:
1. Is the hard-drive empty or formatted? if so then you need to create a partition first:
- start your pc using ur cd if it is bootable (you'll know if it loads some drivers first), if not get a bootable cd
- Run fdisk (type fdisk at the command prompt) and create a primary partition, reboot & format
2. Boot again using your cd, when done switch to the win98se directory and run setup
Thanks for sharing, let me know how it goes
Jul 01, 2011 | HP Compaq Presario SR2010NX PC Desktop
Tip
Creating a bootable flash drive
<p><b>Resolution:</b><br /> <p>The USB Flash Drive must be configured with an active primary MS-DOS partition. It must also contain the boot files. Follow the steps below to create a bootable USB Flash Drive. <br /> <p><b>Requirements:</b><br /> <ul> <li> Motherboard with BIOS that supports USB boot. <li> USB Flash Drive that may be erased. <li> Bootable floppy disk or CD with Fdisk and Format commands. </li></ul> <p><b>Directions:</b><br /> <ol> <li> Plug in the USB Flash Drive. <li> Make the USB drive the only bootable hard drive. <b>Method 1:</b><br />If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. <b> Method 2:</b><br /> Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. <b> Method 3:</b><br /> Unplug all hard drive cables inside the case. If the cables are unplugged the computer cannot detect and boot to the hard drive. <li> Insert the bootable floppy disk or CD into the appropriate drive. <li> Restart the computer to the bootable floppy disk or CD. <li> At the command prompt, type: FDisk. <li> Delete and create a new active primary DOS partition. <li> Use FDisk to delete all partitions from the USB Flash Drive. <ul> <li> In FDisk, press the 3 key to Delete partition or Logical DOS Drive. <li> If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition. <li> After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER. <li> A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER. <li> You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER. <li> The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu. </li></ul> <li> Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2. <ul> <li> In FDisk, press 1 to Create DOS partition or Logical DOS drive. <li> Press 1 to Create a Primary DOS Partition. <li> The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER. <li> The next screen prompts that the computer will now reboot. Press ENTER to continue. </li></ul> <li> Exit FDisk and restart the computer. <li> Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected. <li> At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER. <li> At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER. <li> Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\&gt; command prompt. <li> Change the settings made in step 2 back so that the computer operates normally again. </li></ol>
on Mar 14, 2011 | Computers & Internet
Tip
Creating Bootable USB Flash Drive.
Requirements:
  • Motherboard with BIOS that supports USB boot.
  • USB Flash Drive that may be erased.
  • Bootable floppy disk or CD with Fdisk and Format commands.
Directions:
  1. Plug in the USB Flash Drive.
  2. Make the USB drive the only bootable hard drive. Method 1:
    If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. Method 2:
    Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. Method 3:
  3. Insert the bootable floppy disk or CD into the appropriate drive.
  4. Restart the computer to the bootable floppy disk or CD.
  5. At the command prompt, type: FDisk.
  6. Delete and create a new active primary DOS partition.
  7. Use FDisk to delete all partitions from the USB Flash Drive.
    • In FDisk, press the 3 key to Delete partition or Logical DOS Drive.
    • If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition.
    • After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER.
    • A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER.
    • You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER.
    • The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu.
  8. Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2.
    • In FDisk, press 1 to Create DOS partition or Logical DOS drive.
    • Press 1 to Create a Primary DOS Partition.
    • The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER.
    • The next screen prompts that the computer will now reboot. Press ENTER to continue.
  9. Exit FDisk and restart the computer.
  10. Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected.
  11. At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER.
  12. At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER.
  13. Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\> command prompt.
  14. Change the settings made in step 2 back so that the computer operates normally again.
on Mar 31, 2010 | Computers & Internet
Yesterday I buy a Samsung Laptop model R538 but with Linux Julia preinstaled. I want to change the OS with Win XP. I begin the instalation and at the point in which I know he want to format the disk I get...
Solution:
1. Boot into Linux.
2. Use "fdisk" command to delete "ext" partitions. // In fact, no need to use other tools (e.g. killdisk)
3. Run "fdisk" command as root.
4. For those who don't know how to use "fdisk", I provide an example here. (Read the man page of "fdisk" will be better)
//Remember !!! fdisk can format your hard disk (which will erase all your data), use it with great care -- unless you know what you are doing, otherwise don't use it. (I will not take any responsibility of my suggestion)
i) fdisk /dev/sda
.) For those who use PATA (Parallel IDE) : fdisk /dev/hda
.) For those who use second hard disk : fdisk /dev/sdb (2nd SATA hard disk), fdisk /dev/hdb (2nd PATA hard disk), fdisk /dev/sdc (3rd SATA hard disk) and so on ... {sd [a, b, c, d, ...]}
.) fdisk "what" depends on where your linux partition is.
ii) use "m" to read the available options
iii) press "d"
iv) press the number of the partition you want to delete
v) Remember ! if you don't want to make the change, press "q" at any time. (that means quit without saving)
vi) If you want to make the change, press "w" (that means write the change to hard disk)
5. There may sometimes cause a warning message say something about not synchronize the disk (because you cannot make changes while you are using the partition -- if you are booting the partition now), the change will occur after you shutdown and reboot the system.
6. Okay, you can reboot the system now and you will find that the partition is empty now.
7. You can install XP or what ever now.
** For those who cannot use "fdisk", my simplest suggestion is to re-install Linux if you don't have any other tools (such as killdisk). And then you should be able to use "fdisk". In fedora 8, you can even choose formatting the hard disk in "vfat" file system (which can be recognized by almost all computer include windows xp and so on -- see "File Allocation Table" wiki) during installation. Therefore, no need to run fdisk
May 31, 2017 | Hitachi Travelstar 5K500.B HTS545050B9A300...
My hp touchsmart 300 hard drive went out i got another hard drive but it needs to be formatted and pratitioned but i cant figure out how to do that
  • Start the computer in Command Prompt Mode. Type "FDISK." The partition window will appear with menu options. Enter 5 if you're partitioning a second drive, and select the drive; otherwise, skip to the next step. Enter 1 (Create DOS Partition or Logical DOS Drive). Enter 2 (Create Extended DOS) to create a partition. Enter N when the program asks if you want to use the maximum available size. Designate the amount of disk space to allocate to the second partition (the partition will be assigned the next drive letter) Type a name for the new partition and press Enter. The partition menu will appear. Repeat steps 5 through 8 to create additional partitions. Press Esc to exit the partition command. Format the newly created partitions
  • Jul 28, 2010 | HP Computers & Internet
    Aspire 6930 has 320 GB harddisk,i faced some problem with Avasti Antivirus n i formatted the system to run my system smoothly, but now the problem is harddisk is showing only 128 GB. that too the partition...
    You can Reformat the system and REMOVE all partitions. Windows setup will create a new partition from available drive space. If you need to save your data,You can also use a utility like partition Magic and resize the partition. There is a trial version available at no charge. just google "partition magic"
    Aug 05, 2009 | Acer Aspire 6930-6771 Laptop
    I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
    For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
    FDISK LIMITATION WITH 64GB DRIVES:
    Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
    There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
    http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
    When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
    The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
    NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
    Direct English Version download:
    http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
    This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
    Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
    Sata
    yes you'll have to format the drive before you put xp on...you can use a boot disk with something like fdisk on it...you can boot using a HIREN boot disk (which has FDISK on it) or Roadstarter which is a bootable CD with a whole host of utilities including FDISK.....
    or boot with a windows XP disk and choose the repair with console option ...at the command prompt type in FDISK and you will wipe all the data and partition tables ....giving you a raw data drive to install Win XP to
    Dec 22, 2008 | HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP...
    Hard drive problem
    hmm...could be a problem with the drive. How are you formatting it? Is it in DOS mode or are your formatting it under Windows? If it's in DOS mode and it's encountering that problem, there's a possiblity that it could be damaged. Don't loose hope, try to run FDISK command on the hard drive. Delete the partitions on it and create a new one. After running FDISK on it, format it again and check if the same problem occurs. If it still occurs, there's a problem on the hard drive.
    Jan 02, 2008 | Western Digital Caviar WD400AB 40 GB Hard...
    Hdd disk problem
    U SHOULD USE DISK MANAGER SOFTWARE
    Dec 24, 2007 | Samsung Spinpoint MP0402H 40 GB Hard Drive
    Samsung Spinpoint MP0402H 40 GB Hard Drive Logo
    227 people viewed this question
    Top Samsung Computers & Internet Experts
    270rexton
    270rexton
    Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
