Question about Troy-Bilt Garden
Need flywheel K161T tiller 7 hp kohler
Troy-bilt 7hp kohler engine spec#281181
  • 437 Answers
Go to www.precisionope.com. Find Kohler under OEM parts.
Good Day.
Posted on Oct 07, 2009
How can I find a parts manual/breakdown for an older Troy Bilt tiller? I beleive it was manufactured in 1987 possible model #870487 definite S/N 87 46 39. This tiller has the 8 HP Kohler engine. I am...
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to this website and type in horse for your model number and you should be able to find a parts break down for your tiller. If the serial number is 874639 it was made in 3/88 and will be a four speed PTO model.
I find a lot of parts on Ebay for these tillers, your can order parts through MTD but they will be a little pricey. MTD aquired Troy Bilt out of bankruptcy in 2001 and still carries parts for the tillers.
Frank
Jun 27, 2010 | Troy-Bilt Garden
Magnet location on flywheel of a tecumseh 4 hp on a Ariens snow b
what is going on with the magnets on flywheel or are you talking about the magneto ( coil)
Jan 13, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
What is the gap between the ignition module and the flywheel magnets on the Kohler M8 ST motor,used on the Horse tiller.
The gap is between .015" - .020" when you tighten it down it gets closer so if possible use a .023" shim between the pick up and the magnet to hold it in place.
Jul 22, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have a horse model about 35 years old with a kohler motor 7 horse. What new motor fits. serial no. 360331
In my opinion, (which doesn't count for much, I know) the 7hp Kohler Troy Bilt Horse tiller was the best tiller ever made. Those tillers lasted forever if they were taken care of. I've got one of the 8hp Kohler versions, but it's just not the same.
It's become a lot harder to find an engine to replace these engines. You'll most certainly want to go to a Briggs and Stratton dealer and have them look it up. You need a 3/4" crank, 2 7/8" long with a keyway, tapped for a bolt to hold on the pulley and reverse disc. IF you find an engine to fit, you'll likely need to have a custom throttle cable made up to replace the current one. A good small engine dealer should be able to help you.
Now for the bad news. The 7hp Kohler was a cast iron engine. Any replacement engine you find will likely be an aluminum block with a cast iron sleeve and therefore, much lighter. What this means is the balance of the tiller, from front to back, is going to be thrown off. The result is - it will be MUCH harder to pick up the rear of the tiller when you want to turn at the end of the garden. You will most likely need to either put on one of the bumpers (if you can find one to fit) or figure out a way to hang some weight on the engine. I've seen people do some creative things to get the balance back. Whatever you do, it just won't be the same as that great 7hp Kohler. I'd suggest trying to rebuild it - if possible!
Jun 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
How do I change the belts on a troy bilt tiller
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
May 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Parts list for Kohler K161T engine was mounted on a Troybilt Horse - older model. Need stator number - would like to see parts list or internet site to access it. Kohler has no spark
I have a troybilt tiller with a K161T Kohler 7 horsepowe engine. I have replaced all electrical components, spark plug, points, condenser, stater, all wiring, and cleaned magnets, but to no avail. I still have no spark. The points open and close properly, the plug is gapped correctly. Does anyone have an idea?
Apr 05, 2009 | Garden
I am trying to get amanual for a troy bilt tiller s/n 7492483 mod#k161t spec#281181j
troy bilt says that there is no such model number.if you would check it again and i'll look for one for you. or you can go to http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_TroyBilt_10101_19502_-1 and look for yor self.
Mar 09, 2009 | Garden
Garden Logo
504 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
