Question about Philips CDR795 2-Disc CD Recorder
Display is no longer working
Although it will still play the display on my Phillips CDR775 is completly dark. Have turned it off and on, gave it a little tap here and there but still no display.
Je ne peux pas gravé le avec cet apparaille
Posted on Dec 30, 2007
White screen appears at start up
A laptop suffering from a blank screen can fully impede all computer productivity, but fortunately there are a number of common problems that you can swiftly troubleshoot for in your own home, even if you have no prior computer troubleshooting experience. The power adapter, monitor brightness settings, inverter cable or otherwise may all be possible causes for your screen's problems, but all can be repaired with only a Phillips screwdriver and a potential replacement screen.
Check the power adapter of the laptop and ensure that it is still properly plugged into the back of the machine. Check the monitor brightness settings for your screen. There are dedicated monitor brightness keys on the keyboard, typically located just above the numeric keys. If the brightness has accidentally been turned all the way down, this will result in a screen that appears completely dark or blank. Turn the brightness up. Open up your display to check on the backlight's functioning. Remove the screws that run around the bezel, or perimeter, of your laptop's screen. Use a Phillips screwdriver. Pull the bezel carefully off the display, starting at one corner and working around the bezel until it is completely detached. Find the inverter board, which will now be visible with the bezel removed. It lies at the bottom of the screen. A black inverter cable connects into this board via a connector that lies atop the board. This cable is instrumental to the operation of the screen's backlight, so if the cable has come loose, then the backlight will fail to function and the screen will be dark and blank. Reconnect the inverter cable into the connector by inserting it and then snapping the connector down into the flat, "locked" position, which will put it parallel to the inverter board. Consider full replacement of the screen if the inverter cable fix does not restore the screen's proper operating state. Ensure the inverter cable is disconnected, then remove the metal brackets on either side of the screen. These brackets are held in place with two screws that must be removed with your Phillips screwdriver. Pull the laptop's screen slowly up and out. Slide in the replacement screen, then restore the screen brackets and reconnect the inverter cable. Slide the bezel back into place over the display and replace the bezel screws. Hope this helps
Dec 10, 2012 | Computers & Internet
The righthand (player) side of my Phiips CDR775 will play cds that I have recorded but will no longer play originals. I have used a cd lens cleaner but problem remains.
It may need a better cleaning by a professional as well as some lubrication at points in the unit. This is a job for a Technician.
Dec 07, 2012 | Philips CDR775 2-Disc CD Recorder
Sony Bravia model #KDL52WL130 worked fine for first year then picture went very dark for the 1st 30 minutes it was on but eventually cleared up. Now it takes longer and screen is completely blank. Sound...
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years, some sooner, because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Venta-sonic VS 207 humidifier. Turns on but the display just flashes lights. I had it stored all summer (followed the manual instructions) and it's the first time I'm turning it on.
I had the same problem. During the cleaning process, the white float was installed upside down and humidifier water level sensor was unable to read the float. I removed the phillips screw and inverted the float with the dark ring toward the bottm. Quick fix.
Nov 08, 2009 | Venta Airwasher VS 207 3.7 Gallon...
The display on my Philips cdr775 will not work but the machine still plays discs.
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common in sony. Good luck
Sep 27, 2009 | Sony Handycam DCR-HC90 Mini DV Digital...
Inside display is completely dark, doesn't work.
you need a new flexable ribbon cable. try ebay or
Dec 19, 2008 | Pioneer DEH-P9600MP CD Player
No video on monitor
Go to Start->Control Panel -> Display, Settings Tab, and turn down the resolution of your computer.
Mar 03, 2008 | Dell E193FP 19" LCD Monitor
Pink-hued display
one try a degauss
second check the cable wich connect the monitor to the pc video card.
third. keep away the magnetic things like speackers from the monitor..
Feb 03, 2008 | Compaq CV 7500 17" CRT Monitor
Philips display went out when power outage occurred
I can supply a replacement display from a scrapped unit, I'm in the UK, search on ebay for seller fluffcat1 and contact me.
Oct 04, 2007 | Philips CDR775 2-Disc CD Recorder
Philips CDR795 2-Disc CD Recorder Logo
314 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
