Question about Whirlpool Refrigerators
MY MO GD22DFXFN02 REFRIGERATOR FREEZES UP AND THE COMPRESSOR DOES NOT SHUT DOWN. THE PROBLEM ABATED AFTER I SHUT THE REFRIGERATOR OFF AND RESTARED IT AFTER SEVERAL HOURS AND IT CYCLED ON AND OFF FINE FOR ABOUT 2 WEEKS AND NOW IT IS THE FREEZE UP MODE AGAIN. COULD IT BE THE DEFROST CLOCK OR THE THERMOSAT?
  • 308 Answers
Yes, it is most likely the defrost timer, the timer isn't running anymore, the evaporator coil freezes up and your problems begin. Hope this helps
Posted on Oct 07, 2009
T36it71nnp freezer shuts down
Compressor sounds at fault, rather than pcb.Replacement required?
May 10, 2012 | Thermador T36IT71NNP (196 cu ft) Bottom...
Things in freezer melt and re-freeze
Your condenser fan motor at the compressor is either filthy or needing to be replaced. Air flow is pulled over compressor to keep it at a good operating temp. If the fan cannot pull air across compressor it will over heat and shut down on overload. Imagine working in yard on hot summer day and wearing a dust mask over your mouth and nose. Your body shuts down more needing more rest. Same thing with refrigerators, they have to be able to breathe properly also.
Jan 27, 2010 | GE Freezers
The refrigerator ignores temperature setting.
Hello, This problem is going to be the cold control/thermostat, this part can be located in the control console inside the fridge bhind the freezer temp control knob (can also be found sometimes in the freezer depending on type/model) The reason your food in the fridge is freezing is because the thermostat controling the freezer temp is not shutting down and the air being blown into the fridge is too cold. Replace this cold control/thermostat and you should be fixed. If you have any other questions or concerns please feel free to comment again and give me some time to respond. Good luck! Mike
Sep 08, 2009 | Kenmore Refrigerators
Unit compressor keep short cycling not feezing or
replace your compressor relay. that's what goes wrong 99% of the time
Jul 15, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
F/Freezer ARC7470: Compressor shuts down when set
Issue sems with the relay switch need to change/repair.
Jul 06, 2009 | Whirlpool Refrigerators
Fridge problems
There is a damper between the Freezer section and the Refrigerator sections. If the damper is open to much the refrigerator will freeze up and it will freeze food. Find this damper and close to about 1/2 way.
The Thermostat is seperate make sure this is set around the middle setting. If the thermostat is bad it can cause the refrigerator to also freeze. Turn the dial down and listen for the compressor to click off. then wait a few minuites turn it up and see if the compressor come back on. If you turn the Thermostat all the way down it will shut off with the switch. not shut off by satisifying the temp. so just turn it down slowly and see if it is working.
May 20, 2008 | Hoover HCA390FFK Bottom Freezer...
Fridge does get cold
Sounds like the motor starter/capacitor may be faulty. How long does the compressor run for? Do you hear a clicking every few minutes from the compressor? If a power surge fried the defrost timer that too could give similar results.
Dec 17, 2006 | KitchenAid Superba KSCS23IN Side by Side...
Refrigerators Logo
66 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
