Question about Hotpoint Refrigerators
Fridge makes an odd rattling or woodpecker like sound intermittently. What could this be? Thanks.
  • velvrab Oct 07, 2009
    OK, thanks for the quick response.
    Novelist:
  • 128 Answers
If you have an icemaker, that would be the sound of either the mechanism emptying the cubes or the water valve shutting off. If the water valve is going bad, or the switch that shuts off the water valve is going bad, the water valve may 'chatter'. If this is the case, try shutting off the icemaker, or even the water supply to the unit to see if it stops.
If you don't have an icemaker, then the circulation fan may be rattling a bit or has something in it, like a bit of paper. Circulation fans are typically behind a panel in the freezer sectionon most models.
Some units rattle the metal cooling pipes a bit when the compressor motor starts up. This is a more metallic clanging sound.
If it's a very sharp repeated clicking noise, that may be the sound of the motor-start capacitor going bad.
Posted on Oct 07, 2009
Makes a woodpecker type sound for a few seconds intermittently. Sound like its coming from the middle of the refridgerator.
on the top left inside your fridge side there is a motor that opens and closes a little vent coming from the freezer side. one of the gears may be broken.
Oct 20, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge was making a loud rattling noise for a few days and now is no longer cooling
Check the drain holes are clear within the fridge and freezer and that the compressor is working - it should work intermittently. Please provide a response.
Aug 19, 2011 | Samsung Refrigerators
My tower fan intermittently sounds like there is a woodpecker inside of it. Help!
:) a clump of dust may have fallen against the fan,, clean the unit of any built up debris and check the fan blade for any wobble
Jul 15, 2011 | Lasko 2530 Elite WindTower Fan
My kenmore fridge - 4 years old - has developed an intermittant rattle. Stops when the door is open on fridge or freezer. Starts again if you open the door but hold down the light button so it...
That button just turns the interior light on when you open the door and off when you close it. Could a light bulb be slightly unscrewed? Or perhaps the bulb cover is loose?
Dec 27, 2010 | Refrigerators
My built in side by side is making a noise about every 30 minutes or so that sounds like a woodpecker pecking on it...about 10 times. It is driving me crazy! Have any idea what this might be?
I have the exact problem with my built0in side-by-side Monogram. 1 yr 3 months old, and it sounds m=like a woodpecker for 3 seconds approximately 1ce/hr. Does not appear related to ice maker. You can create the sound by changing the temp setting on the drawer at the bottom. As you command a lower temp, the sound happens a couple seconds. Actually sounds like a solenoid opening and closing at 60Hz frequency, as though a control board were feeding AC to a DC coil. Any ideas? Fortunately, this fridge has a 2 year warranty, but this should not happen to a $6K dual condenser fridge in just over a year!!
Jan 09, 2010 | GE Monogram® ZISS420DMSS Side by Side...
Intermittent rattling noise in refrigerator
Do you have an ice maker? That noise could be the ice maker trying unsuccessfully to dump ice, usually caused by a defective heater to loosen the ice cubes prior to dumping them into the container.
Possibly even if your ice maker appears to be functioning normally, it may be attempting to dump ice several times before the ice is actually ejected and if you don't use a lot of ice, you'd never notice it.
Hope this helps.
Jun 27, 2009 | GE Monogram Refrigerator Built-In...
Rattle and Gurgling noises
It's the fan bouncing off the fan-motor housing. The best way to stop this is to shim the motor mount so the fan will ride with the motor shaft "out" preventing it from bouncing. When you raise the fridge on one corner you are doing the same thing the shim will accomplish.
The draining gurgling sound is probaby freezer defrost water being pushed down the drain tube into the drip pan at the bottom. The door action pushes/pulls air in the tube and pushes out water.
May 27, 2009 | Refrigerators
Whirlpool Fridge Making a rattling noise
There are 2 areas it could be in....The upper area where the evaporator fan is....or the lower area where the condenser fan is..
If it is in the freezer...when you open the door there should be a button that the door connects with that you can hold in manually to make the fan engage..and listen for the noise..the odds are if it were ice build up....your thumping the fridge would not make it stop ..since the thumping would not remove the Ice...it would continue to build up and the fan would eventually stop completely and everything would warm up. It could be a loose stap that holds evaporator lines in place or a motor mount that is loose ..
Or it could have to do with the condenser fan..where the compressor is.The compressor and condenser coil are located underneath the freezer section of your refrigerator. There is some tubing connecting the compressor to the condenser coil. There is also a condenser fan to cool the condenser. To access these parts the refrigerator has to be pulled away from the wall. If you pull the refrigerator out go slowly and watch the tubing that connects from the water valve on the back of the refrigerator to the water cut off at the wall.
Remove the power from the refrigerator. Remove the lower panel on the rear of the refrigerator. Look inside for anything loose. Locate the condenser fan motor and blade. These are the areas to stay away from when power is applied. Plug the refrigerator back in being careful to avoid the condenser fan motor and blade. Wear gloves to prevent burning yourself on the hot refrigerant lines and try touching tubing and lightly pushing and pulling to see if you can cause or stop the noise.
Generally a rattle or hum is caused by a refrigerant line touching part of the cabinet or base pan. If it is not repaired it may rub a hole in the refrigerant line causing the refrigerant to leak out. If you don't feel comfortable trying to correct it, you should schedule service and let a technician repair the refrigerator.
I hope this helps...please rate me ...thanks The Fang
Mar 26, 2009 | Refrigerators
Hi, i have an Bosch just over a year old and it has just recently started making a noise from the back of the unit. It sounds like a fan rubbing or rattling, it stops as soon as the fridge door is opened.
hi thanks for the question .It sounds like the fan in the fridge is rubbing locate the fan and clean out the obstacle thanks the appliance doc
Sep 29, 2008 | Refrigerators
Not getting cold
if the rattle is coming from your compressor it would cost more to fix than the fridge is worth i'm sure. the compressor is the only moving part on the unit. the only other component is the thermostat. which you can bypass to see if it cools.
Oct 29, 2007 | Sanyo 4.4 cu. ft Counter-High...
Refrigerators Logo
541 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
