Question about Philips 483521837121 Remote Control
Can you help me?
  • Please help me fine the codes?
  • I have 3 universal remotes and can not get any of them to program to the t.v.
  • 1 is a pm435
  • 2 is a Philips 6/1
  • 3 is a GE -rm24912
  • please help
    Sergeant:
    Champion:
  • 362 Answers
A lot of remotes and tv have some matching codes, some are common do you point the remote at the tv until the red light blinks 2 times on the remote then try a combination of these codes, also you can go on line and type in the manufacturer name of the tv and put codes behind the name that will usually get you what you want example " panasonic lcd codes.com " but here are some common codes. 0019, 0054, 0057, 0150,0178, 0765, 1276, 1256, 1262, 1314,1316. these work on many tv's and so forth generic codes.
Posted on Dec 27, 2007
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
Tip
Programming Philips Universal Remote Control To Your Device
Program the Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2. Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3. Release the Setup button
4. Press the button to which you want to programme(TV/VCD/DVD).
5. Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7. If the device responds, you have successfully programmed your Philips universal remote.
8. If the remote is not programmed then, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
1. Turn all of your devices off, and then manually turn on the device you want to program.
6. Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To Get The Programming Codes :
Please go to below website to get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote model.
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
Attached a image for your reference:
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
on Jul 27, 2010 | Televison & Video
Lost programing instructions and codes
1. turn on device
2. press setup (underneath on/off) till red light stays on the take finger off the button
3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once
4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press
5. press and release enter to install code
3-Digits Universal Remote Codes
4-Digits Universal Remote Codes
GE #24912 Universal Remote Instructions
GE Universal Remote Instructions
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Apr 15, 2011 | GE JASRM24912 Remote Control
I need universal remonte codes for sanyo tv the universal remote is rca
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/RCU703_DOC_CODES.pdf lists of all the codes for that remote and http://voxrightnow.custhelp.com/app/answers/detail/a_id/11447/session/L2F2LzEvc2lkL0JJNmtTRnBr
how to program the remote please let me know if this helps
Mar 23, 2011 | RCA Universal Remote Control 3-in-1...
I have and old floor modal tv in good condition I have a Rca universal remote that I dont have the program codes and cant seem to fine them online
As we dont know the TV make you can use code search method.
It basically searchs the codes automatically.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
4. Release "CODE SEARCH".
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
If you can find the codes for your /tv please follow the below steps
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
Thank you
Aug 07, 2010 | RCA 6-Device Universal Remote
Im trying to find out the code i need to use in order to program my ge universal remote to my magnavox tv
One of these should do the job.
Magnavox 0 0 5 4 ,1 2 5 4 ,0 0 3 0 ,0 1 7 9 ,0 1 8 7 ,0 0 9 6 ,
0 0 2 0 ,0 1 8 6 ,0 3 8 6 ,0 0 2 4
Please rate my help++++Thanks for using FIXYA
Jun 28, 2010 | Universal Remote Control GE174Universal...
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
Can you help me program my remote?
hi i have a philips universal a rca tv and a dvd named lennox sound 2003 i want to program the dvd with the remote please help no codes lost
Feb 09, 2009 | Philips Universal PH301S Remote Control
Universal Remote iwave
I Have The Codes,But No instructions!! Big IWave . 0054-Philips Hitachi-0145 JVC-0053 LG- 0178 OR 1265
Jun 09, 2008 | Hitachi 50HDA39 50 in. Plasma HDTV
Programming my nexxtech 3-in-1 remote control
looking for instructions for  remote control nexxtech 3 in 1 universal
Oct 28, 2007 | Televison & Video
Televison & Video Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
