Physical installation of 2nd hdd
Could you give step by step instructions with photos for installing a second sata hard disk drive in my pc with ATX tower cabinet and gigabyte g-31 motherboard?
    Guru:
  • 81 Answers
The document below gives instruction for installing, but the place and shape of the cabinet and hdd case may be different from you PC. You can use this as a refrence. Installing a hard disk drive Use the steps in this section to install a new hard drive into an empty drive bay. Step 1
If you are installing a new hard disk drive, make sure it is set to cable select. physical installation of 2nd hdd - c01179815.jpg Step 2
Slide the hard disk drive into the hard drive cage. c01196498.jpg Step 3
Align the screw holes on the hard drive with the screw holes on the hard drive cphysical installation of 2nd hdd - c01179817.jpgc="http://i.fixya.net/uploads/images/c01179817.jpg" alt="c01179817.jpg" class="h_mi" /> NOTE: Make sure the connectorsphysical installation of 2nd hdd - c01179818.jpgop of the hard drive cage. c01179818.jpg Step 4
Replace the four physical installation of 2nd hdd - c01179813.jpgn each side) to secure the hard drive to the hard drive cage. c01179813.jpg Step 5
physical installation of 2nd hdd - c01179809.jpgower and data cables to the drive. The connectors are keyed and can be attached in only one way. c01179809.jpg
Insert the hard drive cage into the PC.
Align the four tabs on tphysical installation of 2nd hdd - c01179820.jpge hard drive cage with... c01179819.jpg
physical installation of 2nd hdd - c01179821.jpghe four slots inside the PC. c011798physical installation of 2nd hdd - c01179822.jpg= Align the three tabs on the side of the hard drive cage with ... ... the three slots on the front of the PC. c01179822.jpg Step 7
physical installation of 2nd hdd - c01196500.gifhe hard drive cage down until it snaps into place. c01196499.gifphysical installation of 2nd hdd - c01179804.jpg NOTE: Make sure the front tabs on the hard drive cage are correctly inserted into the slots on the front of the PC. c01196500.gif Step 8
Replace the two screws that secure the hard drive cage to the PC. cphysical installation of 2nd hdd - c01833532.gif class= Step 9
If you are adding another hard drive instead of replacing a hard drive, connect the SATA data cable for the new hard drive to the next available SATA connector on the mother board.
NOTE: The SATA data connectors on *********** board may look slightly different than the example. c01833532.gif Step 10
Replace the front panel and the side panel, and then reconnect the cables.
For more information about replacing the side panelphysical installation of 2nd hdd - c01179827.jpgt cover, refer to the HP support documents Removing the Front Cover and Opening the PC Case . c01179827.jpg Step 11
If using Windows, wait until Windows finds and configures the new drive. c00615034.gif
Regards,
Shrey
Posted on Oct 08, 2009
Secondary hard drive for dv9205us
You may install a hard disk drive (HDD) or solid state drive (SSD). Regardless of which you choose, it must have a SATA connection. After installing the drive, be certain the BIOS of the notebook sees it and you should be good to go.
Jan 06, 2014 | HP Pavilion dv9205us Notebook
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
Mother board masi km4am-l H.D.D. 1 TRA WES 64MB when installing win xp hard not detected by win setup. I updated bios but not worked. advance thanks
you should not update the bios...the issue is the hard disk is on sata ...and you need a raid driver installed to detect the hdd...so ...either get into BIOS and under advanced features..look the place where the drives are detected..and select the hdd and look for a feature called AHCI ..and disable it ..and leave sata like ide..and save with f10 and restart ...after that the hdd will be seen ..
another way is to make a floppy disk with the raid driver on it (the one from the mothermoard drivers disk ) ..and when it ask you to press f6 for 3rd party software ...press it ..and insert the floppy ...it will pick up the raid driver and will go like a charm ..
if you do not have a floppy ..install a second cd drive ..and use a cd ..and after pressing f6 for 3rd party ..browse and point to the raid driver on the mobo driver cd ..
Jul 15, 2011 | MSI KM4AM-L VIA KM400A CHIPSET ULTRA...
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
Installed a WD Caviar Green SATA internal hard drive in my Gateway PC. The bios doesn't show it, the device mangler doesn't show it. I disable the antivirus software & the UAC as suggested by the many...
New HDD Not Recognized by Computer
This occurs when the HDD is not “Initialized” by the disc management system in Windows. If you do not have software that came with HDD or the HDD is a secondary drive for backup and is not to be used as an initial boot device, then when you installed the drive it did not go through the necessary steps or Windows simply failed to do it’s job. In this case, connect the drive as you normally would, go to the control panel > Administrative Tools > Computer Management > Look in the left Pane, scroll down and click on Disk Management.
Your drives will be listed here, even if they are not initialized. Look below the top pane and find the disk that is listed without a drive letter. If you look at where the drive is named, it will also say “offline”. Right click in this area that says “offline” and click on “Initialize”. The system will ask a few questions, just click ok to what it asks, this will initialize the disk and you can then partition the new drive to how you want it set up.
Jan 18, 2010 | Computers & Internet
Help installing new HDD
chain the drives. use the second plug on same cord first drive is plugged into
May 28, 2009 | E-Machines eMachines Desktop PC
Set up did not find any hard disk drivers installed on computer
Your notebook has SATA hdd. Got into the bios (keep pressing F2 key on startup) then in the bios screen find HDD and press enter. Select IDE mode. Press f10 to save changes and exit. When this is done install XP.
Alternatively connect external usb floppy drive and unzip sata drivers into that. When booting from xp cd press f6 to load drivers.Follow onscreen instructions to load drivers and continue xp installation.
Please let me know if issue not solved for futher ts steps.
thanx
May 28, 2009 | Fujitsu LIFEBOOK P1510D Tablet PC
I have an Accer Extensa 5220 laptop which came with vista Home Edition. I wanted to down grade the OS to windows XP Pro. After formating the Hard Drive, I ran windows XP setup disk but keeps on giving the...
The problem of your laptop is the hard disk type. because acer 5220 laptop is using a SATA hardisk that automatic detected or supported by Vista. But in the windows Xp you need to download the sata driver for windows xp and save it to the floppy drive. In the beginning of windows installation press F6 to install another device or scsi the windows setup search your floppy drive for the sata driver and install it automatically. If you have cannot fix it just contact me i'm willing to help you
Apr 15, 2008 | Computers & Internet
WD not turning
First enable the hard drive in bios if you havent already .Then if you have windows xp click right on my computer and select manage,it opens up computer mangement, then go to the tab called storage and on the sub menu of storage click disk management . You should see you 2nd/other hard drive (labelled disk 1 at the bottom if it is the second hard drive) make sure its your 2nd HDD ( Look at capacity in properties by clicking right on it) .Click right on the 2nd hard drive and select format press ok when the new window comes up and its finished.
Nov 15, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
