Has trouble during the drain/spin cycle.sometimes itseems to not spin at all
    Problem Solver:
  • 4 Answers
Get some descaling stuff from tesco and give the washing machine a good clean to rid limescale
Posted on Oct 07, 2009
Softener tray is not draining during wash cycle
This tray empties during the spin cycle not wash cycle. Is the agitator spinning during the spin cycle? If so, you are getting softener on clothes during this cycle as required.
Feb 17, 2015 | Kenmore HE3T Washer
Kenmore washer needs two spin cycles
Have you checked the timer? Sometimes the little motor inside of it gets stuck or the concacts become burnt.
Good luck,
Marty
Jun 21, 2014 | Kenmore Washing Machines
Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
May 23, 2014 | Whirlpool Washing Machines
Whirlpool Thin Twin randomly skips agitation during the cycle.
Did you ever figure this out? Mine agitates but instead doesn't start spinning and draining unless I open the lid. It then "clicks" and starts but it is strange that I have to do this to get it to spin.
Dec 20, 2012 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
Washer won't spin during rinse cycle. agitates fine during was cycle.
The lid switch is probably your culprit. the washer won't spin or drain if the lid switch is defective. Try pushing down on it with a pen or small screwdriver and see if it will spin then. There should be a slight clicking nois when it is activated, although it will sometimes click even though it is not working.
Nov 15, 2010 | Whirlpool LSR5132PQ Top Load Washer
Leaks very badly during spin cycles
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem that you find. Also, the steel or plastic outer tubs can rust, split, or be punctured. If that happens, the entire outer tub would need replaced, but that might not be an economical repair to make and would require professional assistance. Hopefully, the main drain line is leaking and can be repaired. Sorry for your trouble and I hope this helped. Best wishes.
Aug 25, 2009 | Washing Machines
Spin cycle
it sounds like there is either an obstruction in the pump, or the load is getting off balance during the spin cycle. two things to try, fill the washer with no cloths in it, when it starts to agitate, stop the cycle and put it in drain/spin cycle. the water should be out in under a minute. its hard to see because the door locks, but you can hear a difference in the pump when its out, or after 60 seconds, press cancel and open the lid to check. if the waters out in that time, the pumps ok. then run it through the spin diagnostic with a load of cloths. make sure the cloths are wet, and a normal load you wash. this will check to see if the load is getting off balance, and shutting down during the spin cycle. let me know if you still have the problem. good luck, shane
Aug 23, 2009 | Maytag Neptune Washer
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
My simpson esprit 600 is not agitating during wash cycle it only goes one way
Im having troubles with mine. Just not sure what to replace..
The wash cycle is fine however when it comes to drain and spin cycle, the water doesnt drain. It does make a noise during this cycle but im not sure whether the drain pump need replacing or the drain pump motor?
Can anybody help?
Aug 18, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
