Question about Acomdata E5 HD320UHE5-72 320 GB USB 2.0 Hard Drive
Unit powers up and attempts to connect to pc, actually does connect for a second and then disappears, then constantly reconnects and disappears...
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 07, 2009
No power the power light would not stay on
Sounds like a malfunctioning a/c adapter. I suggest the following:
  • Spray the power connections with an electronic parts cleanser.
  • Reconnect and see if the problem has disappeared.
  • If not, try another adapter.
  • If the problem still doesn't disappear, call support desk of the manufacturer.
May 30, 2012 | Computers & Internet
I've got a Dell Dimension 5150. After connecting to the mains the power light is blinking amber for some time, it then disappears and only then the computer can be booted. Unfortunately this delay is...
Check POST Boot messages for a flat Battery; Check Front control panel circuit over (remove); Check other USB connectors; Try a replacement Power Supply Unit.
Sep 12, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
Same monitor, same problem!!!
While the unit is attempting to "come ready", disconnect and reconnect the 7 wire blue plug. Some how or another, this disrupts the start up pattern that is failing, and the monitor comes on as normal when reconnected???
Oct 01, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Overload LED lit, constant warning tone, no load on unit. Is there an internal component available to repair this unit?
I have seen this caused by a defective battery. Disconnect the battery and reconnect to AC and see if the overload symptom disappears.
Lou
Sep 11, 2009 | APC Back-UPS XS900 (BX900) UPS System
I have an Acer H243H widescreen monitor; it has speakers built in. My problem is that the Volume controls constantly show up on the screen and I am unable to get it to go away and stay gone. The touch...
When this occurs with mine, I power down the PC through windows and the monitor using the lower right power button, let bot sit for 10 - 20 seconds, then power on the PC and switch on the monitor a second or two later and the icon disappears.
Before I did this I found it would eventually disappear.
Acer support claim the H243H is a touchscreen unit, that's what the icon is all about, buy you must have Vista to use it, not XP.
Jul 15, 2009 | Acer Computers & Internet
How do you store radio station in memory?
you have the constant power wire and switched wire backwards.
Switch the red and yellow wires around.
Thanks for using FixYa - A FixYa rating is appreciated!!
Feb 16, 2009 | JVC KD-HDR1 CD Player
Constantly 'Finding Hardware'
On  Windows XP right clic on My Computer, clic on Properties --> Hardware --> Device Manager , identify the "New" unknown hardware, it gotta be under a big yelloy question mark, once identified you can right clic on it and clic "Disable" or if it happens to be a necesary device, look for its drivers and install it.
Good Luck!!!!!
Jan 30, 2009 | Dell Inspiron 1501 Notebook
D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 08, 2009 | D-Link AirPlus DI-524 Wireless Router
Panasonic dmr-es35v
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
Jul 29, 2008 | Panasonic DMR-ES35VS
Power connected right, pops fuses in player
HI Paul,
No one evidently wants to tell you that your Radio is shot. The circuits in the head units is not worth repairing. It is too minute and hard to do to the point it isnt worthy of attempt. I do not mean to be the harbinger of doom here. Just get a new head unit and this time dont get an Audiovox.
Aug 23, 2007 | Audiovox P88 CD Player
Acomdata E5 HD320UHE5-72 320 GB USB 2.0 Hard Drive Logo
131 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
