Question about Samsung Spinpoint MP0402H 40 GB Hard Drive
Hdd disk problem
I have problem to fdisk on samsung 40gb hard disk
when i run fdisk command first partition go to 79% and repet it in 100% other it repet 100% . what i do to slove?
    Problem Solver:
  • 8 Answers
U SHOULD USE DISK MANAGER SOFTWARE
Posted on Dec 25, 2007
Yesterday I buy a Samsung Laptop model R538 but with Linux Julia preinstaled. I want to change the OS with Win XP. I begin the instalation and at the point in which I know he want to format the disk I get...
Solution:
1. Boot into Linux.
2. Use "fdisk" command to delete "ext" partitions. // In fact, no need to use other tools (e.g. killdisk)
3. Run "fdisk" command as root.
4. For those who don't know how to use "fdisk", I provide an example here. (Read the man page of "fdisk" will be better)
//Remember !!! fdisk can format your hard disk (which will erase all your data), use it with great care -- unless you know what you are doing, otherwise don't use it. (I will not take any responsibility of my suggestion)
i) fdisk /dev/sda
.) For those who use PATA (Parallel IDE) : fdisk /dev/hda
.) For those who use second hard disk : fdisk /dev/sdb (2nd SATA hard disk), fdisk /dev/hdb (2nd PATA hard disk), fdisk /dev/sdc (3rd SATA hard disk) and so on ... {sd [a, b, c, d, ...]}
.) fdisk "what" depends on where your linux partition is.
ii) use "m" to read the available options
iii) press "d"
iv) press the number of the partition you want to delete
v) Remember ! if you don't want to make the change, press "q" at any time. (that means quit without saving)
vi) If you want to make the change, press "w" (that means write the change to hard disk)
5. There may sometimes cause a warning message say something about not synchronize the disk (because you cannot make changes while you are using the partition -- if you are booting the partition now), the change will occur after you shutdown and reboot the system.
6. Okay, you can reboot the system now and you will find that the partition is empty now.
7. You can install XP or what ever now.
** For those who cannot use "fdisk", my simplest suggestion is to re-install Linux if you don't have any other tools (such as killdisk). And then you should be able to use "fdisk". In fedora 8, you can even choose formatting the hard disk in "vfat" file system (which can be recognized by almost all computer include windows xp and so on -- see "File Allocation Table" wiki) during installation. Therefore, no need to run fdisk
May 31, 2017 | Hitachi Travelstar 5K500.B HTS545050B9A300...
Xp install disk cant find any hard drives on my hp pavillion dv 5000. it was given to me without any install disks
You will have to delete the partitions of the hard drive before using the xp disk because if there is any partitions formatted as EXT (non dos) the xp disk will not read them. You can download a dos disk of the internet to do this. Once you have used the fdisk command which you can use to re-partition your hdd you should be able to install xp no problem.
Jan 22, 2010 | Computers & Internet
I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Samsung 40 GB Spin Point Hard Drive problem
try to use some Hard drive recovery programes or try Paragon partition manager.
Sep 29, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Hard Disk Partition
you have make Bookable floppy to boot & restart when it show 3 types you can choose without cd rom sopport and type fdisk then u can edit from there.
Sep 21, 2008 | Maxtor Hard Drive
SEAGATE HARD DISK DRIVE PROBLEM...
I am venturing a guess, but it could possibly be your memory and not your hard drive.
Additionally, you can partition and format the 40Gb HD in a second PC using a third party utility such as Partition Magic which would also allow you to verify the integrity of the hard drive
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 01, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Samsung harddisk problem
How to Find Bad sectors and how to block bad sectors manually?
Dec 24, 2007 | Samsung Spinpoint MP0402H 40 GB Hard Drive
SAMSUNG SV0411N HDD SHOWN ONLY 7.85 GB
you seem to have a hidden partition Have you used FDISK ? this can be downloaded just do a search You then need to remove all partitions - you seem to have only formatted part of the drive.
Jun 02, 2007 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Samsung Spinpoint MP0402H 40 GB Hard Drive Logo
193 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
