Question about Sony DAV-BC150 System
No Sound in any mode
I have had this HT system for about two years and at some point it stopped providing output to the speakers.
Audio CDs, DVD movies, AM, FM, no audio from anything.
The panel display indicates that the discs are being read.
Video displays from both outputs to the monitor.
I've checked the speaker connections. Nothing seems amiss.
  • 2 more comments
  • Anonymous Jan 06, 2008
    Yes,Just same problem..
    Have you somebody fixed this problem? Please tell me how to fixed it.
  • jim22905 May 31, 2008
    My system is 3 years od and the audio stopped working without any notice. No function works, the headphone jack is also out.
  • notmissing Aug 10, 2008
    Hi all,
    Also have the same problem. Connections and everything else seems ok
  • Anonymous Nov 22, 2008
    Same problem but it''s definetly not a mix up with headphones as even the headphone output won't recieve the sound.
I had the same problem... but I knew that my 2 yr old had been playing with the headphone jack on the BC-150. Evidently, the system thought that headphones were still plugged in to the port on the front right of the unit, even though none were present. The solution that worked for me was to take some headphones, plug them COMPLETELY into the system (another set of headphones would not insert all the way, so I found a new set and used those to completely insert into the headphone port) while playing a CD and listen for a few seconds and then simply unplug them. Viola! Sound came back. Hope this helps.
Posted on Aug 20, 2008
  • neojr_hacksy Dec 20, 2010
    Still having the same problem.
    Connection OK.
    Speaker OK.
    Wire OK.
    No sound from speakers. When I start music DVD theatre just jumps to standby mode. I can hear music from headset but with allot of whitenoise.
    Any solution ?
Code to change settings for Small loud speakers to large. Model No HT-F450K to HT-F455K models
Speaker size selection usually is part of receiver set up; the DVD player has nothing to do with it.
Jun 27, 2016 | Samsung HT-C650W DVD Home Theater System,...
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
How to I get my surround sound speakers to work with the cable box?
One way would be to connect one of the the digital audio outputs to the HT as an input (HDMI or optical digital audio).
Another would be to select one of the DSP modes that uses surround speakers. They work with all input modes.
http://downloadcenter.samsung.com/content/UM/200802/20080203110035031_HT-Z510-XAA-0125.pdf
Jan 28, 2011 | Samsung HT-TZ512T Theater System with...
How do i connect the sound of the tv through the sound bars speakers
you can connect the audio output pin in tv R/L channel and in sound systems audio R/L input
and put the sound system in line-in mode..........try
Jun 19, 2009 | Samsung HT-X810T Theater System
No sound out of 4 of 5 speakers when using tv only.
switch around rca cords and verify its not a bad wire(s),Check and see in the TV menu audio settings are correct/ balances R/L etc. audio outputs are on,Try different theater amp if you have an extra.
Jan 26, 2009 | Samsung HT-X50 System
Sound Problems with HD TV
This seems to be a problem that has to do with your HDMI audio output.
First check in your TV setting if audio out is selected on your correct HDMI port. Than check if your receiver is able to receive audio via HDMI (i assume you used the HDMI connection). Some receivers have HDMI IN connections but are not able to receive audio on it, the latest receivers/sets do have this feature. If your receiver doesnot support audio IN via HDMI you can only do one thing, connect the stereo audio-out of your TV to an AUX IN connection on your receiver.
Jan 18, 2009 | Samsung HT-Q100 System
No Surround Sound in Aux 2 mode
genarally tv output contain two signals.(steereo).it dosent have surrund output.thats y its not hearing surround sound from your system.
Jan 07, 2009 | Samsung HT-WX70 Theater System
There is no sound from speakers in the t.v. mode
you have to hook up seperate audio cables for the tv you may have to set onto aux mode for your tv
Nov 10, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Ht-ddw790
Check the setup menu on your TV. Many models require that you choose between using the internal speakers and using the speaker outputs. Sometimes the TV menu choices are "FIXED" (audio output) or "VARIABLE" (internal speakers).
Feb 05, 2008 | Sony HT-DDW790 System
Sony DAV-BC150 System Logo
321 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
