Question about HP LaserJet 4250n Printer
Have to manually press print on the printer
I have to manually press print on the printer in order for some jobs to print. This is a shared computer.
    Scholar:
  • 131 Answers
Make sure you and the other person both have the exact same paper type in you rprinter defaults in print properties. This is usually the case as the printer is looking for different paper size or type.
Hope this helps
Posted on Oct 07, 2009
Testimonial: "thank you! explanation put in simple terms. love it!"
  • Jim Rearick Nov 08, 2010
    I have found that setting both tray 1and tray 2 size and type of paper (under the "paper handling" menu) to "any size" and "any type" usually solves those types of issues.
    Give it a try.
    Keep in mind that the "manual feed" setting will also be a factor.
    For some reason, this setting is found under the "configure device" menu.
Printer will not switch on. stuck on standby
STEP 1
Remove any other pending print jobs in the printers que until you are left with just the problem ones. Just click on each print job and choose cancel!
If a print job in the que shows "deleting" but never completes the command;
  • Go to Start then choose Run
  • Type " net stop spooler " and press Enter
  • Wait for the DOS window to open then close.
  • Go to Start then Run & type "net start spooler" press Enter
If this does not work Go To Step2
STEP 2
If that does not cancel the print job:
Your Windows XP spool directory is located at
C:\WINDOWS\SYSTEM32\SPOOL\PRINTERS
On a Windows 2000 machine the path is usually
C:\WINNT\SYSTEM32\SPOOL\PRINTERS
It will Usually will contain files looking like these:
FP00008
FP00008.SHD
There will be two files for each remaining print job. Just delete these and reboot your computer. Your print queue should now be cleared.
*** To delete the print files type " del *.* " in the correct directory and press Enter. * Make sure you are in the right path i.e., C:\WINDOWS\SYSTEM32\SPOOL\PRINTERS
If that does not work Go To Step3
If you are printing over the network, and cannot get the print job to clear the que after the above steps:
Go to the computer that has the shared printer attached and perform Steps 1 & 2 above.
If that does not work then go to the computer where the Print Job was sent from and perform steps 1 & 2 on that computer.
If everything above did not work then try this...
Step 3
If all of this does not work then run a disk check on the computer that has the printer attached
  • Type " CMD " and press Enter
  • Wait for the DOS window to open.
  • Type " CHKDSK C: /R /F " if C:\ is where your OS is installed!
  • Answer Y for yes and press enter
  • Reboot your computer and wait for the Disk Check to complete
Apr 21, 2012 | Canon Pixma MP480 All-In-One InkJet...
How can I to stop printing when I have order to print to a hp Laser P1006
hi
when you press the PRINT button, soon afterward a small icon in the bottom right corner of your computer will appear. double click it, whn it opens select the print jon and press the dlete button on your computer. or youc an slect print job, left click (mouse) and select CANCEL print job
does this help you ?
Nov 14, 2010 | Epson Printer
Laserjet 1022 not printing on shared computers
on printer properties try to set on sharing tab check marks on : share this printer- render print jobs on client computers- list in the directory ..( all of this must be chacked).. on port tab see on what port is printer ..(tcp/ip - or virtual), on advance tab.. check alway available, spool print documents first., under security see if you have set group permission.. if you did not ,, add the computers to use this printer ( in most cases this is the problem).... if all of the above s set , and you can still not able to print .. enter in run...services.msc... find print spooler and restart it .. then try to print.
Dec 02, 2009 | HP LaserJet 1022 Printer
Sharing two computers won't complete print jobs. The printer prints two pages then stores the print jobs in a que. I have to keep rebooting?
ok forst of all you should re install the drivers of printer and re cheak the both of the computers re configure all if not solve then tell me again.
Nov 25, 2009 | Epson Stylus CX3810 All-In-One InkJet...
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
I have a Brother HL2070N printer. I have 2 computers and want to share the printer. I connected the printer via the USB port to Computer 1 and it prints fine. I set the printer to SHARED. Computer 1 has...
hi there,
Because printers and networks vary, the best instructions for setting up and networking your printer should be in its users manual. Also, your network-ready printer may have come with installation software that can help you share the printer over the network.
There are three main steps you need to take when networking a printer, including the following: Enable the File And Printer Sharing setting, Make the printer available to all users, and Direct PCs to the printer.
For detailed instructions on sharing printers at home, please refer to the "Get Your House In Order" article in the "See Also:" section below.
For detailed instructions on sharing printers in a small business, please refer to the "Select & Share The Right Printer For Your Small Business"
Apr 14, 2009 | Brother Office Equipment & Supplies
HP 2015 Printer not printing as a shared printer
Hi Ronmur,
Few checks...
1. Is there sufficient diskspace for to queue print jobs?
2. There a corrupted print job that is holding the queue. Find the which application on which computer sent the print job. Send it again to see if it holds up the print queue.
Dec 15, 2008 | Office Equipment & Supplies
Brother HL-5240 printer problem
This usually means a print job is stuck in the queue that was set to "manual feed" or to a different paper size, such as legal. Add paper to the front manual feed and press "Go". If this is the problem, the stuck document will begin printing from the manual tray.
To clear the problem without printing from the manual feed, cancel all jobs on the printer, delete any jobs out of the Windows print queue and restart the computer.
Dec 04, 2008 | Brother HL-5240 Laser Printer
Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Oct 26, 2008 | HP LaserJet 1018 Printer
HP LaserJet 4250n Printer Logo
111 people viewed this question
Seeker5211
Seeker5211
