Question about Toshiba Satellite M100 Notebook
There is no bios setting comes and also no operating system found message come and also format not star
  • 591 Answers
Every computer needs a BIOS and an Operating System. The key combination to get to the BIOS is displayed on the screen for a couple of seconds at system startup. If you fail to press those keys the computer will try to start any existing OS. If no OS is found then you MUST install one to use your computer.
Posted on Oct 08, 2009
Operating System Not Found Message
dsflews 1 or 2 HDD ?
made any changes in BIOS ?
if 2 HDDs and you set optimal defaults in BIOS windows can change BOOTDISK. if two it's easy just change back.
http://www.pcmag.com/encyclopedia/term/38515/beep-codes
good reading.
Apr 19, 2013 | Dell Dimension XPS PC Desktop
Compaq presario 2594 us laptop , after boot-up get message ( operating system not found) tried recovery disc, will not formate hdd , will get this message in windows set-up , SET-UP...
I've gist had the same problem after flashing bios ...
go to BIOS and change the SATA mode to IDE. it worked for me.
original instructions:
also You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
PLUS it seems if only 128 MB is showing as memory then the memory sticks might be damaged and not able to retain information/data to complete the installation process. Best take them out clean it properly & replace & try again. Nothing to do with BIOS!
Jun 11, 2011 | Compaq Presario 2594us Notebook PC...
When booting the laptop it says PXE-E61: media
When you start your computer, the motherboard searches connected drives for the operating system. The search order is usually the optical (CD/DVD) drive first, possibly a USB drive next, then the hard drive. If none of these work, some systems are set to try booting the operating system over a network cable. What the cryptic message you're getting is telling you is that the system tried a network boot without success, and that maybe the trouble is a bad cable.
This all means that your hard drive isn't being detected, or that there's no longer an operating system on it. It's possible the connector from the hard drive to the motherboard has come loose, which can sometimes happen since laptops get moved around. The hard drive may have gone bad, or there may be a problem with the motherboard that is causing it not to find the hard drive. Or the hardware may all be fine, but something (a virus or other malware, for instance) has deleted files needed to load Windows.
When the computer first starts, you'll see a message about how to enter BIOS setup. The BIOS is the motherboard's built-in program, and through the setup pages you can see what devices it detects. This will let you know if the hard drive is being found. Some boards include diagnostic tests you can run on the hard drive if problems are found. You can also check the boot order; you may find that for some reason the boot order has been changed so that the network boot is being tried first. Strange things can happen to BIOS settings, often a sign that the backup battery for the memory where the settings are stored is getting weak.
If you have access to a Windows XP operating system CD, you can set the BIOS to boot from the CD drive and try using the Recovery Console feature. Information about this can be found at Microsoft's site.
Good luck getting your laptop back up and running quickly. Thanks for using Fixya!
May 29, 2011 | Acer Computers & Internet
Message come while installing realtek audio driver not found
You might have option to install Realtek Audio Drivers in the CD itself.
Mar 08, 2010 | Intel DG31PR Motherboard
My Compaq Presario 700 CM2130 failed to boot one day out of the blue. It just gave me an error message saying Operating System Not Found. I put in the disk for Windows XP and after a few minutes of loading...
When you get to the BIOS window, do you get a message saying that is going to shut down in some period of time of does it just shut down?
Here is my best guess and solution. I believe you've got a worm virus. If you have nothing that you want on this hard drive, and you've got a full install Windows XP disk, I'd do a full install with a complete format, not a quick format, FAT32, if you can, NTFS, if you can't and reinstall Windows XP.
Oct 18, 2009 | Computers & Internet
Power hard disc
This message comes when your harddisk is not detected in bios.
When you power up the laptop press
F1 or F2 or "del" key to enter in bios setup.
Then check SATA is disable. then save settings then restart .
Jul 30, 2009 | IBM ThinkPad T30 2366 Notebook
OPERATING SYSTEM NOT FOUND MESSAGE
HI,
This can be an issue with the hard drive..
Go to bios by tapping F10 while the system boots > go to diagnostics and select hdd self test.
If it given an error "No IDE device found" then try reseating the hard drive. i.e. take it out and put it back in.
Otherwise try changing the boot order by going to advance / system configuration > select boot order > select the hdd and pess F6 till it goes to the top. Press F10 to save and exit.
Hope this helps..
Regards,
Anup
Apr 08, 2009 | Compaq Presario 700US Notebook
PXE-E53 and 1962 No operating system found error messages
Install Windows XP and then Ubuntu
Any Linux Using GRUB (preferably) Or LILO will automatically fix all "No Operating System found etc. Problems"
Sep 11, 2008 | IBM NetVista PC Desktop
Error loading operating system
Firstly have you set your jumpers on your hard drive setting before placing into computer. If not check if the cd rom is on the same cable, if on same cable then change the jumper.
Have you gone into bios and loaded the hard drive. If a new hard drive you will need to detect it in bios first. Then Save and exit.
To go into bios, press f1 or f2 or DEL when you first start computer. Each computer is differentand you'll have to see which you require to press.
After bios is setup, put in your copy of windows xp, or your boot disks and follow instructions to set partition and format drive, then install operating system.
If you are only installing a new secondary drive as a backup, you will still need to detect in bios first. Then load you windows and go to my computer and format the drive using windows.
Aug 05, 2008 | Computers & Internet
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
Computers & Internet Logo
146 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
