Question about Motorola Mobility RAZR V3
Morola v3 battery don't work properly...
When I turn on my motorola v3, keypad turns on but both displays no. When I press the battery it start working for a while, aprox. for 30 min, then turns off. I think it's battery problem. Some disconect between phone and battery, if it possible?
  • 416 Answers
No not in the moto razr.....what its sounds like is a fault between the main board and the lcd flip top........open the back panel by removing the battery back and battery and the screws. It will just pop off now. Make sure that when u put it bck together the ribbon cable from the lcd panel is firmly secured to the board. TRy it again GOOD LUCK
Posted on Oct 07, 2009
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
Keypad acting up!
SURGICAL - you need to replaced the mobile flexcable in the phone also have the repair center flash the keypad flexfile back into the phone.
BRENNA - replaced the flexcable
VGETSON - you need to flash a file call keypad flex into the phone to correct the keypad freezing up on you.
Sep 27, 2008 | Motorola Mobility RAZR V3
My keypad won't work
Sounds like the power button is possibly stuck or broken. Razr's aren't very durable. Did it get wet or dropped recently?
Jan 23, 2008 | Motorola Mobility RAZR V3
Motorola razr v3 keypad....!!!
This is usually caused by one button being stuck down, and the volume control buttons on the left of the main display, and the voice button on the right of the main display are the usual culprits. Try squeezing them and making sure they move normally. Then power down the phone, pop out the battery, and give it another shot.
Dec 15, 2007 | Motorola Mobility RAZR V3
Motorola razr v3 keypad problem!!
Press all of the buttons and keys on the phone one by one with it powered off and the battery out. Make sure they all feel normal to the touch and when pressed. Check the buttons on either side of the main display carefully, as these tend to get stuck more than others.
Motorola v3
look take the battery out and let it sit over night and then u put the battery back in the phone and then put it on the charger when it finish charging cut it on it should work
Aug 11, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Display turned off, but i can make and receive calls
If you take the battery out then with the battery out plug in the charger, this worked for me.
Jun 15, 2007 | Motorola Mobility RAZR V3
Screen out side
I hope this anser helps you: First, Press the center select key to open the menu, then scroll to SETTINGS & TOOLS and then go to Display Settings, and press the center select key to select it, nou you should go to "Clock Format" and press the menu key. Scroll to Front Clock (for the external display) and press the center select key THAT IS!
May 24, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
63 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
